will B18A oil pan work with B16A
Old Jun 30, 2002 | 09:27 AM
b00stedsi's Avatar
Default will B18A oil pan work with B16A
Well I have my turbo kit sitting here and I cant install it because my oil pan has a slow leak. A buddy has an 90-93 b18a ls pan for me. Has anyone put a b18a on a b16a. Will this be ok? Any problems?
Thanks
Old Jun 30, 2002 | 09:38 AM
earl's Avatar
Default Re: will B18A oil pan work with B16A (turkish)
I always thought they were identical. They just don't fit on engines like the b18c because of the girdle.
Old Jun 30, 2002 | 11:12 AM
SiRkid's Avatar
Default Re: will B18A oil pan work with B16A (earl)
what year b16????
the new ones have a girdle aswell!
[Modified by SiRkid, 8:12 PM 6/30/2002]
Old Jun 30, 2002 | 11:27 AM
turbo Si's Avatar
Default Re: will B18A oil pan work with B16A (SiRkid)
Of what I remember hearing is that non vtec oil pans pick ups are not in the same spot as vtec oil pans. Check into that though!
Old Jun 30, 2002 | 12:01 PM
sgT's Avatar
sgT
what year b16????
What year did they start doing that????
earl: they are identical
Old Jun 30, 2002 | 02:14 PM
SiRkid's Avatar
Default Re: will B18A oil pan work with B16A (sgT)
i dont know if the sols came with it or not? i know the 99/00 SI's DO FOR SURE!
hmmm.
Old Jun 30, 2002 | 03:28 PM
turbo Si's Avatar
No they don't! GSR's and H22's have block girdles. Z-10 Engineering recently started making them for B16's. I remember because back then they tested it on Kubo's car.
Old Jun 30, 2002 | 08:24 PM
b00stedsi's Avatar
what year b16????
Sorry,it's a b16a2..
Old Jun 30, 2002 | 08:29 PM
synergy004's Avatar
I have a old B16A oil pan on my B18A1 motor, i figure it should work.
Old Jun 30, 2002 | 09:23 PM
rioninja's Avatar
My 90 LS oil pan is 100% identical to my B16a oil pan (late 90s JDM motor).
So yes, it will work.
Old Jul 1, 2002 | 06:23 AM
boosted hybrid's Avatar
Yup I am using a b18b LS pan on my b16a, and the pans are absolutely identical.
As far as block girdles goes, i have/had 4 b16a blocks each of which were stripped down and none have had factory block girdles. I havent gotten my hands on a 99/00 Si block, but i would only assume that they dont have girdles on them. The sol's didnt, i have two of those blocks sitting here at my house right now...girdle free.
Old Jul 1, 2002 | 06:26 AM
Speed PHreak's Avatar
Default Re: will B18A oil pan work with B16A (boosted hybrid)
B16B's have a block girdle. Not the B16A's just to clear things up The B16B is just a destroked ITR/GS-R block anyways, so thats why it has a block girdle.
[Modified by Speed PHreak, 3:42 PM 7/1/2002]
Old Jul 1, 2002 | 06:30 AM
turbo Si's Avatar
Default Re: will B18A oil pan work with B16A (Speed PHreak)
Hum.....that's intresting to know!
Old Jul 1, 2002 | 06:43 AM
internet ay's Avatar
Default Re: will B18A oil pan work with B16A (turbo Si)
if i use a z-10 block girdle on my b18a will i still be able to use the b18a oil pan??
Old Jul 1, 2002 | 07:16 AM
Default Re: will B18A oil pan work with B16A (internet ay)
No. You'll need ; GS-R/ITR Oil pan, oil pickup, windage tray, and the 6 GS-R main bolts that go into the girdle.
Instead of a Z-10 you could use the stock GS-R/ITR girdle.
Go here to see how
[Modified by Speed PHreak, 4:17 PM 7/1/2002]
Old Jul 1, 2002 | 08:02 AM
well the z10 girldle is already in the b18 block with the gs-r main bolts, oil pickup, and windage tray but my motor is still at the shop so i havent had a chance to see if the oil pan will work.so i guess i will need a gs-r oil pan. crap.
Freeltec
Jan 18, 2006 08:36 AM
SleepinTeg
Jun 16, 2005 08:54 PM
Turbocoupe97
Sep 5, 2004 12:18 PM
slwazgsr
Sep 3, 2002 06:47 AM
