wideband showing running lean
Well i cracked a cylinder wall which caused a ton of coolant to rush through my exhaust. I fixed the motor and the car started right up. When im accelerating the wideband goes to 16-17:1 would the coolant have ruined the sensor causing it to give a false reading?
replace the sensor and you will know your answer.
Test the sensor before wasting 80 bucks its not hard. Take a rag, soak in carb cleaner, stick sensor in if it goes full rich and stays for a long time sensor is good, if it goes full rich and starts going lean after a short amount of time sensor is bad
