Wideband Sensor Placement: after resonated test pipe ok?
Old Sep 25, 2004 | 05:59 AM
acurar0ss's Avatar
Default Wideband Sensor Placement: after resonated test pipe ok?
I have the powercore race cat, which is basically a resonated test pipe with no cat element. I placed the o2 sensor after the exhaust streem goes through the resonated test pipe, is this ok or will my readings be affected?
I searched and after a regular cat the consesus is no good, but what about a resonated test pipe?
Old Sep 25, 2004 | 09:00 AM
Flamenco-T's Avatar
Default Re: Wideband Sensor Placement: after resonated test pipe ok? (acurar0ss)
You'd want to get the wideband sensor as close as you can from the head. The farther you are from the head, the heat will dissipate and gives you false reading as to the actual temperature are.
Most of time, try to get the wideband around 3-5 inches from the turbo. Even if you're about 18" ish, you'd still be okay, I just think the resonated test pipe will be too far off from the turbo causing you to get a little bit lower number that the actual number.
stan
Old Sep 25, 2004 | 10:38 AM
acurar0ss's Avatar
Default Re: Wideband Sensor Placement: after resonated test pipe ok? (Flamenco-T)
thanks, so when dyno tuners put the wideband in the tailpipe (non cat cars) this is not as accurate as if they were to put it closer to the head..... just wondering if it is worth it to move the sensor closer forward or just leave it.
Old Sep 25, 2004 | 12:16 PM
acurar0ss's Avatar
mmm......
Old Sep 25, 2004 | 04:10 PM
DruWO's Avatar
Dyno tuners put the sensor in the tailpipe to save time, cause welding in a bung and all that **** will take up more time. Most tuners subtract .75 from the actual reading, and they say thats what the reading would be if the sensor was up by the head.
edit: and i say you move that sensor up closer to the turbo...peace!
Old Sep 26, 2004 | 08:47 AM
acurar0ss's Avatar
Default Re: (DruWO)
just because I am bored I am going to move it closer to the head and compare those readings to the ones I am getting after the test pipe...... in case anybody else is interested I will post my results........
Old Sep 29, 2004 | 04:04 AM
acurar0ss's Avatar
Default Re: (acurar0ss)
I moved the sensor up closer to the head (about 18" from the turbo) and my readings are ***** on to the readings after the test pipe. I took readings throughout the rpm range before I moved the sensor and after I moved it forward. I think I am going to leave it after the test pipe since it would be cooler and in the innovate pdf file it says if the sensor is cooler it will last longer.
Old Sep 29, 2004 | 04:38 AM
igo4bmx's Avatar
i bought an ebay high flow cat (resonator) and it came with two 02 bungs, which maybe how i will be running my regular and wideband o2 at the same time
Dc2_ShowStopper
Honda CR-V & Element
Feb 5, 2013 05:07 AM
401tuner
Jun 3, 2007 04:03 PM
H23A1LUDE
Jun 5, 2003 08:17 AM
done
Jul 5, 2002 12:10 AM
