Why does my boost build so slowly?
Old May 16, 2013 | 08:05 PM
  #26
cruizinmax's Avatar
Default Re: Why does my boost build so slowly?
Originally Posted by ohsnapzafingcu
D-rob is going to redo my tune and have more duty cycle from the solenoid so I receive full boost earlier. I'll load it and see how it goes, if it still doesn't work i'll go ahead and re-route my vacuum lines
An easy way to test the theory would be to put a tee between the vacuum block and the boost solenoid then run that to the bottom of the wastegate. Just leave the line from the compressor housing unplugged temporarily. That line does not see vacuum.
Old May 19, 2013 | 08:40 AM
  #27
ohsnapzafingcu's Avatar
I serve phở for my babies
Rob: setting the different values, how do you know what different duty cycles constitute different PSI targets?
Old May 22, 2013 | 06:17 AM
  #28
HondaPro1's Avatar
what fuel pressure should you run on 8 lbs?
Old May 22, 2013 | 07:49 PM
  #29
anything is fine, as long as your motor gets tuned. 35-55 psi is fine
2percent7
Jun 4, 2008 04:16 AM
rollagti
Oct 22, 2006 06:03 AM
S2KP
Jul 28, 2004 06:36 AM
PUREVIL
Jun 23, 2003 06:23 PM
