whos runnin' s200b?
Old Jan 31, 2005 | 10:31 AM
B00STED Si's Avatar
Default whos runnin' s200b?
ive noticed lately, about 3/4 of the time im at WOT a rev limiter will kick in around 6500rpms and other times it wont. I know its not the boost limiter tho. i dunno if it has to do with the hondata s200b or not. Any idea of what could be causing this? thanks.
Old Jan 31, 2005 | 10:32 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm running S200B with no issues. I have hit boost cut a few times on a cold night drive.
Old Jan 31, 2005 | 11:52 AM
Quad-Damag's Avatar
Default Re: (DaX)
Im runing a s200 b and i have never hit boost cutout with my old greddy kit
Old Jan 31, 2005 | 12:03 PM
Rod.'s Avatar
Default Re: (Quad-Damge)
i am running s200b. Have you talked to your tuner?
Old Jan 31, 2005 | 03:44 PM
B00STED Si's Avatar
Default Re: (redturbocivic)
the tuner is in japan now, haha, so i cant contact him. it was tuned about a year ago and this problem just arose in the past day. im thinking it has something to do with the s200b unit itself. the LED indicator light on the unit will stay solid red for 6 seconds, then goes out for a split second, and as far as i know the indicator LED is supposed to not blink at all. so im guessing the problem might be related to that? but then again im not sure because the indicator light has been doing that for a while now...
Old Jan 31, 2005 | 05:11 PM
B00STED Si's Avatar
Default Re: (B00STED Si)
am i the only one thats only had this happen?? any hondata tuners on the boards have an idea??
Old Jan 31, 2005 | 05:53 PM
DaX's Avatar
DaX
Loved
Community Favorite
Have you tried telephoning Hondata? It will probably yield the best results for you.
Old Jan 31, 2005 | 05:56 PM
97hb's Avatar
Default Re:
I would check the ribbon connector that goes from the ecu to the blue box. Might be loose.
Old Jan 31, 2005 | 06:07 PM
B00STED Si's Avatar
Default Re: (DaX)
DaX,
i contacted hondata, and all they could say is "all i can think of is the connection to the clutch pedal" which wasnt much help to me.
I also checked the ribbon connecting wire which is hooked up fine.
i was hoping someone on here had the same issue...or a hondata tuner would know what to do with this situation. the closest hondata tuning facility around here is JE Performance, which i might go to if i cannot resolve this myself.
Old Jan 31, 2005 | 07:10 PM
UberTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">whos runnin' s200b?</TD></TR></TABLE>
memememememe
Old Jan 31, 2005 | 07:12 PM
22psicrx's Avatar
We tuned a type r in a crx w/ 8 psi and it kept redlining at 6500rpm, did it off and on, look for a ckeck engine light and check the code. His check engine light did not work but Hondaloger picked it up. It turned out to be a cylinder sensor in the dizzy .also check your wiring from dist. hope this helps.
Old Jan 31, 2005 | 07:25 PM
B00STED Si's Avatar
Default Re: (22psicrx)
thats EXACTLY whats happening to me, i will check it asap and get back to you. thanks guys!
Old Feb 1, 2005 | 07:47 AM
t0p_sh0tta's Avatar
22psicrx, who tunes Hondata in Connecticut?
bumblebeehatch
Engine Management and Tuning
Mar 11, 2013 06:07 PM
jdmland
Jul 8, 2008 10:18 AM
Lucky_Smurf
Dec 16, 2005 09:45 AM
B00STED Si
Apr 8, 2005 08:53 AM
