Whos blown there sohc engine on the dyno?
Old Oct 21, 2003 | 12:05 AM
Drew Peacock's Avatar
Default Whos blown there sohc engine on the dyno?
I am thinking about turning the boost upto 15psi on my stock D16a6 I have had it upto 12psi and it go's well. If the A/F ratios are good and theres no detonation do you think I would get away with making around 250- 260whp on a stock sohc. Turboo is a BB ihi VF22, LINK adjusts ignition and controlls extra injectors. I would either be using 50/50 93 0ct and 114 oct low lead or straight 114oct.
Old Dec 21, 2003 | 12:18 PM
JDMs1eeper's Avatar
Default Re: Whos blown there sohc engine on the dyno? (turbozxi)
Good Luck
Old Dec 21, 2003 | 12:23 PM
sporkcrx's Avatar
Default Re: Whos blown there sohc engine on the dyno? (Typesi2nv)
I think it'll survive on the dyno...but I don't know how long it'll last. Damn those rods!
Old Dec 21, 2003 | 01:04 PM
lazerus's Avatar
Default Re: Whos blown there sohc engine on the dyno? (sporkcrx)
i would save up for a new motor before i get ballsy and ruin my ownly ride.. but thats me, and if it was my only ride!
Old Dec 21, 2003 | 01:18 PM
NINJASPY's Avatar
Default Re: Whos blown there sohc engine on the dyno? (lazerus)
I have no idea how big or how many cfms your "Turboo is a BB ihi VF22"
puts out, but d-series rods let loose at around ~250hp. I wouldnt try it until I had a backup plan(extra motor, extra parts, or $$$ up the wazoo).
But if you try it, good luck d-powa
Old Dec 21, 2003 | 02:35 PM
norcalcrx's Avatar
Default Re: Whos blown there sohc engine on the dyno? (NINJASPY)
Go for it. I am running 10psi daily making that power. See my sig. As long as its tuned right.
Old Dec 22, 2003 | 06:37 PM
Default Re: Whos blown there sohc engine on the dyno? (norcalcrx)
Haha where did this thread come back from...
I ended up dynoing at 12psi drops to 11psi after 6000rpms, made 215whp and am out of injector. Will be heading back once I have a 8 injector style setup, looking for 250whp@ 14-15psi) on 112octane, will report how it go's. I think the trick will be to only run that kind of boost when racing at the track... D series even though they woin't let me be a ninja
Nysh
Feb 9, 2007 02:25 PM
Not2farFromtypeR
Jul 25, 2006 01:34 PM
57one
Mar 3, 2003 09:14 PM
JoshM
May 28, 2002 06:14 AM
