Whoa, Car is not grounded?????
Old Jan 11, 2003 | 01:34 PM
intekragsr's Avatar
Default Whoa, Car is not grounded?????
My engine is not grounded, which I just discovered. It hasnt been grounded since I bought the car yea flame me whatever.
All I need to know is, what is the proper way to ground it. Why does the engine need to be grounded and how can it be bad if it is not??
Thank you for you time.
Old Jan 11, 2003 | 01:41 PM
trbob16a's Avatar
Default Re: Whoa, Car is not grounded????? (intekragsr)
OK edited: connect a wire from under the front right valve cover stud. Run a wire from that to the chassis above the headlight, there are some holes to put a screw in. Your transmission should also be grounded on the top of the tranny there should be a ground wire connected.
[Modified by trbob16a, 6:05 PM 1/11/2003]
Old Jan 11, 2003 | 01:42 PM
intekragsr's Avatar
Default Re: Whoa, Car is not grounded????? (trbob16a)
Thanks. What are the downsides of not grounding my engine for this long?
Old Jan 11, 2003 | 01:43 PM
txhatch's Avatar
See the empty hole on the front right of your valve cover? Run a wire from that to the chassis above the headlight, there are some holes to put a screw in. Your transmission should also be grounded on the top of the tranny there should be a ground wire connected.
Arent you actually supposed to use the bolt just to the left of the hole? Where's that pic when you need it.
Old Jan 11, 2003 | 01:45 PM
trbob16a's Avatar
Default Re: Whoa, Car is not grounded????? (txhatch)
Yes, I've heard both, or also using a bolt on the a/c mount. I've never had a problem using either however.
Old Jan 11, 2003 | 02:03 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
i thought it was the bolt to the left of the "hole" too.
edit: yep it sure is, this pic was taken from another thread... this is the proper way to ground it:
[Modified by PreIudeSI, 11:14 PM 1/11/2003]
Old Jan 11, 2003 | 02:38 PM
lucas569's Avatar
ive been running like this for months, i dont thnk this will "damage" the motor, i just gotta get my lazy *** to put a new wire...
Old Jan 11, 2003 | 02:45 PM
T-sohctec's Avatar
Default Re: Whoa, Car is not grounded????? (lucas569)
there are a couple places that the engine (I.E. wire harness is grounded) Nothing will happen if it is not grounded but you can run into things like a weak spark. if the harness was truely not grounded anywhere nothing woul work.
I think.
Old Jan 11, 2003 | 03:02 PM
shortyz's Avatar
Default Re: Whoa, Car is not grounded????? (T-sohctec)
uhm in the first pic i think i see the wire and bolt.. its going down towards the rad.
jvr
Apr 11, 2014 11:56 PM
jvr
Apr 11, 2014 02:47 PM
antivic
Apr 4, 2004 04:30 PM
SleepnCiViC
Mar 21, 2004 07:15 AM
shipsaeki
Nov 7, 2002 03:46 PM
