Where to tap downpipe for o2?
Old Aug 9, 2002 | 08:08 AM
ion_four's Avatar
Default Where to tap downpipe for o2?
Should I go right after the turbo, or will that be too hot for the sensor?
P.S. I'm going to get my downpipe made as soon as I can, today!
[Modified by ion_four, 5:11 PM 8/9/2002]
Old Aug 9, 2002 | 08:14 AM
KC GSR's Avatar
Default Re: Where to tap downpipe for o2? (ion_four)
i know the drag DPs are tapped about 3" from the very end where it connects to your cat/testpipe/exhaust
Old Aug 9, 2002 | 08:22 AM
ion_four's Avatar
Default Re: Where to tap downpipe for o2? (KC GSR)
wow, that's pretty far down...the only thing I could find in a search was someone saying they went 6" from the turbine outlet...hrm...
Old Aug 9, 2002 | 08:27 AM
JM Performance's Avatar
what type of 02? stock, greddy, wideband?
Old Aug 9, 2002 | 08:29 AM
Doodoo's Avatar
I think that was my post. Mine is 3", not 6" from the turbine. BUT my sensor is not heated. If you have a heated sensor, 4 wire, it should be further away, close to the cat.
Old Aug 9, 2002 | 08:34 AM
ion_four's Avatar
Default Re: Where to tap downpipe for o2? (Doodoo)
It is a 4-wire heated Denso stock sensor.
Old Aug 9, 2002 | 10:49 AM
if its a stock sensor, then put it in the stock location....right before the cat.
Old Aug 9, 2002 | 10:52 AM
sgT's Avatar
sgT
Default Re: Where to tap downpipe for o2? (00SilverLS)
Put it close to the turbo, heated or not.
The only reason the stock o2 sensor is by the cat is because its right after the 2-1 merge.
That way its allowed to read all 4 cylinders and not just 1 or 2.
Old Aug 9, 2002 | 12:09 PM
racerxadam's Avatar
Default Re: Where to tap downpipe for o2? (sgT)
Steve, does this rule apply for a wideband o2 also?
Old Aug 9, 2002 | 02:07 PM
filetofit
Guest
Posts: n/a
Default Re: Where to tap downpipe for o2? (racerxadam)
I wanna know too.
Old Aug 9, 2002 | 03:53 PM
sgT's Avatar
sgT
no. because a wide band can account for variations in temperature.
Old Aug 9, 2002 | 03:56 PM
dustin's Avatar
off topic:
I've always wondered how tailpipe wideband O2 sensors can be accurate on cars with catalysts still installed.
Old Aug 9, 2002 | 04:14 PM
speedymon's Avatar
Default Re: Where to tap downpipe for o2? (dustin)
I was told you need a testpipe or hollowed cat for an accurate wideband! Hmmmm.
JDM-Vic
Apr 29, 2010 05:04 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
madman604
May 12, 2003 08:44 AM
R134
Aug 27, 2001 02:08 PM
