where does your sc61 full boost at and how much boost?
Old Jun 16, 2004 | 07:56 PM
S2KP's Avatar
Default where does your sc61 full boost at and how much boost?
What motor are you running the turbo on?
Old Jun 16, 2004 | 08:30 PM
vaporboy12's Avatar
Default Re: where does your sc61 full boost at and how much boost? (Turbo_Siii)
4300k
Old Jun 16, 2004 | 11:19 PM
TheShodan's Avatar
Moderator
Full boost by about 4200, Fully built GS-R. About to sell it, though.. Getting a GT30307
Old Jun 17, 2004 | 12:24 AM
b_ron007's Avatar
and how much is full boost?
Old Jun 17, 2004 | 01:09 AM
S2KP's Avatar
Default Re: (b_ron007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_ron007 &raquo;</TD></TR><TR><TD CLASS="quote">and how much is full boost?</TD></TR></TABLE>
whatever their full boost is set at.....duuh.
Old Jun 17, 2004 | 03:44 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (Turbo_Siii)
SC61E .60/.63 69 trim, stock JDM B16, 4800 5-6 pounds, I think the CTR cams are hurting me, I need to switch to some GSRs
Old Jun 17, 2004 | 04:37 AM
Nextelbuddy's Avatar
well full boost can depend on a cople of things. what psi full boost is...10, 15, 20 psi. also what gear you are in. 1st gear you are going to reach full boost before yuo do in like 4th gear. or at least in my case.
i dotn reach full boost of 24 psi until like 5500-6000 rpms lol. i am still trying to figure out what is wrong. if anything is wrong.
to the guy that reaches full boost by 4500 rpms what gear are you in and what psi is your full boost that reaches in 4500 rpms?
Old Jun 17, 2004 | 06:46 AM
b_ron007's Avatar
i actually meant how much is full boost for each of you? i know what full boost is dinggy. 8O duhhhhh!
Old Jun 17, 2004 | 06:54 AM
DD_JonnyLee's Avatar
mine starts making boost at about 3800 ,then its on like donkey kong at 5200 , thats when vtec comes on. it makes like 3-4 lbs from 3800-5000, then vtec comes on and wham, 12 lbs
Old Jun 17, 2004 | 07:28 AM
pete98m3's Avatar
hmmm makes me wonder when my audi 20v is going to spool with that turbo.
if i was you i would try engaging my vtec a little sooner and see if it spools faster.
Old Jul 27, 2004 | 09:15 PM
leed's Avatar
Default Re: (pete98m3)
B16 9:1cr
SC61 6169E
On a roll on in 3rd I start building boost at around 4k. By 6k I get around 10, and as soon at the cams switch (@6000) it immediately jump to 13 and reaches my max boost of 15psi at around 6400.
IMHO, way too much lag for a B16. Absolutley no fun around town, but does its job well for full on straight line acceleration.
Old Jul 27, 2004 | 10:38 PM
M.A.R.C.'s Avatar
Default Re: (leed)
wow
77mm D16 (~1.7L)
~9.7:1 cr
p&p head
14psi by about 5000-5500rpm...
2.5" dp hurting me BAD... the downpipe flange hole is SMALLER than the outlet of the turbo. so it's blocking off about 1/4" of flow around the outlet.
Old Jul 28, 2004 | 06:36 AM
spooler's Avatar
32psi at around 6400rpm.
90Rexx
Aug 11, 2010 05:05 AM
Project X
Jul 17, 2008 08:38 PM
JrCRXHF
Nov 13, 2003 03:50 AM
djnikko
Aug 14, 2003 03:55 AM
1fstcorrado
Jul 30, 2003 03:17 AM
