where do you guys idle at?
Old Jul 17, 2002 | 09:18 AM
ceemarun's Avatar
Default where do you guys idle at?
w/ 450cc's and hondata, my idle is at 250rpm, and goes up to 750 sometimes, butt usually stays at 250. is this bad? where do you guys idle at?
Old Jul 17, 2002 | 09:21 AM
echo999's Avatar
New User
Default Re: where do you guys idle at? (ceemarun)
My 98 GSR idles around 750-850
Your idle is way too low.
Old Jul 17, 2002 | 09:24 AM
ceemarun's Avatar
Default Re: where do you guys idle at? (echo999)
what size are you using?
Old Jul 17, 2002 | 09:29 AM
Ri5e's Avatar
I'm idling at a solid 750 +- 50 RPMs. 370 cc injectors.
Old Jul 17, 2002 | 09:30 AM
abraunb16's Avatar
New User
Mine idles at 750-800 rpm's and sometimes 850-900 when the fan kicks on in the heat. I'm running 800cc RC's. Later Allen
Old Jul 17, 2002 | 09:35 AM
ceemarun's Avatar
Default Re: where do you guys idle at? (abraunb16)
alright, something is definately wrong then.
Old Jul 17, 2002 | 09:45 AM
Trigun's Avatar
mine idles at 750-800 w/ 440cc + hondata
Old Jul 17, 2002 | 09:47 AM
echo999's Avatar
New User
Hmm.. does it still sound stock? Maybe your tachometer is wrong.
I'm thinking 250rpm would feel very rough.
Old Jul 17, 2002 | 10:15 AM
b18bturbo's Avatar
It should be idling aroudn 700-800 rpm
Old Jul 17, 2002 | 10:23 AM
ceemarun's Avatar
how do i check if the tach is wrong? its at 250, but its smooth as a baby's ***.
Old Jul 17, 2002 | 10:24 AM
*Boostwerks*'s Avatar
Mines at 850.
450 + ZC + ZDyne
Old Jul 17, 2002 | 10:31 AM
technine's Avatar
When I did a motor swap, I idled at 250 until I adjusted the idle control screw. It also idled really really smooth. Sometimes I would think the car was off since it was so quite and cranked it to here grinding from my starter. I kinda liked it at 250, but I kept thinking it might die out at a stop light after hard driving so I raised it anyway.
Old Jul 17, 2002 | 10:33 AM
ceemarun's Avatar
Default Re: where do you guys idle at? (technine)
after i got it tuned on the dyno, i took it out and it would die like crazy at every stop...i was driving at WOT too, and the engine shut off (thats not good). but im driving pretty crazy now and it doesnt die at all. is a low rpm idle bad for the engine?
Old Jul 17, 2002 | 10:35 AM
boostaholic's Avatar
My idle is right at 1000rpms right now. I'm running a Speedpro B2B w/ 550cc's and no IAC valve. Going to work on getting it a tad lower if i can.
Old Jul 17, 2002 | 10:36 AM
DSF's Avatar
DSF
How are you guys reading 250rpm on the stock tach? The first line is 500rpm
Old Jul 17, 2002 | 10:40 AM
ceemarun's Avatar
Default Re: where do you guys idle at? (DSF)
nah, mine has a "0" then a space, then a hash, then some more hashes, then a "1" denoting 1000rpm, and the spaces in between are that between the other marks along the tach...
ah! what i said meant nothing.....its just at 250
DaFredsta
Aug 29, 2011 12:21 PM
B20EF
Apr 21, 2009 10:51 AM
slimbo
May 16, 2004 10:57 PM
BYT
Jul 16, 2002 09:37 PM
