Where to CEL tester?
Old May 3, 2003 | 08:12 PM
Ek00fbp's Avatar
Default Where to CEL tester?
Where can I get a tester for my check engine light to find out the code?
Old May 3, 2003 | 08:18 PM
Flamenco-T's Avatar
Default Re: Where to CEL tester? (Fbp00si)
office depot or staples...it come sin a box of 100 or 500...
it's called paper clip
stan
Old May 3, 2003 | 08:20 PM
TurboTegB18c's Avatar
Default Re: Where to CEL tester? (Flamenco-T)
Speaker wire works for me.
Old May 3, 2003 | 08:33 PM
Ek00fbp's Avatar
Default Re: Where to CEL tester? (TurboD16Z6)
and how do I do it guys? Im sorry, I havent done it before. A freakin paper clip?
Old May 3, 2003 | 08:48 PM
Flamenco-T's Avatar
got my IM ?
Old May 4, 2003 | 04:18 AM
T-RO's Avatar
Passenger side floorboard behind the carpet. Should be two connectors. Stick a wire or paperclip in the two holes of the small one to "jump" the wire. Then turn the key to "on". CEL light will flash the number of the code. Long flashes are the tens digit, short flashes are the ones.
Old May 4, 2003 | 07:52 AM
Daniel's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">Passenger side floorboard behind the carpet. Should be two connectors. Stick a wire or paperclip in the two holes of the small one to "jump" the wire. Then turn the key to "on". CEL light will flash the number of the code. Long flashes are the tens digit, short flashes are the ones.</TD></TR></TABLE>
a little vague, so for more specificity, look for a fat green rubber thing with a blue connector inside of it. Very easy to spot----the green sticks out.
Old May 4, 2003 | 08:25 AM
JT's Avatar
JT
If you have the money and a laptop or palm, you can try something like this. http://www.obd2.com/index_home.html . I used to have one before my Hondata and it tells you all error codes and all avaialble sensor readings. Simply plug the connector to the obd2 port under the dash on the driver side. However, it's only for obd2 vehicles.
Old May 4, 2003 | 11:13 AM
TeStUdO's Avatar
if you want to spend a ton of money you can buy a scan tool from autozone or just use a paperclip like everyone else said
Elijah Herndon
May 22, 2017 03:16 PM
76 camaro car
Aug 1, 2015 12:11 PM
93_hatchie
Engine Management and Tuning
Nov 21, 2009 11:27 AM
accord2civic2prelude
Aug 14, 2008 09:15 PM
R91Si
Oct 10, 2004 02:30 PM
