Where all the SOHC boosters at?
Old Oct 27, 2005 | 10:32 AM
david
Guest
Posts: n/a
Default Where all the SOHC boosters at?
Anyway… I’m at a JDM d15b right now in a del sol and I’m planning to boost in the future. I’m totally new to the darkside but I’ve been reading. I would appreciate ANY feedback/flames. I’m planning to work with the GREDDY turbo kit to start myself off and maybe a front mount intercooler or side mount (depending which ever I need to obtain my goal). My goal is 200 whp DAiLY DRiVEN. If Possible? Thanks in advance. My car is pretty much bone stock right now.
Old Oct 27, 2005 | 11:03 AM
Timmay's Avatar
Default Re: Where all the SOHC boosters at? (david)
9-10lbst on a inercooled greddy kit will make 200whp easy, tuning is your key to how long it will last
Old Oct 27, 2005 | 01:19 PM
BlackCRX's Avatar
all the sohc boosters are busy changing thier blown headgaskets
jk
get a tune tuner or tune it yourself with conservative timing and enough fuel
use arp headbolts
Old Oct 27, 2005 | 01:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (BlackCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">
use arp headbolts
well put. or head studs.
Old Oct 27, 2005 | 02:01 PM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">Anyway… I’m at a JDM d15b right now in a del sol and I’m planning to boost in the future. I’m totally new to the darkside but I’ve been reading. I would appreciate ANY feedback/flames. I’m planning to work with the GREDDY turbo kit to start myself off and maybe a front mount intercooler or side mount (depending which ever I need to obtain my goal). My goal is 200 whp DAiLY DRiVEN. If Possible? Thanks in advance. My car is pretty much bone stock right now.</TD></TR></TABLE>
Some groundwork:
Cheap Reliable Fast - Pick 2
Expect things not to work.
Have a daily driver in reserve.
Things are going to break and/or **** you off - Patience and money go far.
You will still lose races this will also **** you off.
Every action has an opposite and equal reaction.
Do alot of research. Read twice and purchase once.
That should get you started.
Old Oct 27, 2005 | 02:07 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Where all the SOHC boosters at?</TD></TR></TABLE>
We're here man. You can definately meet your goals with the Greddy kit and I would recommend going with the front mount intercooler.
Old Oct 27, 2005 | 09:16 PM
david
Guest
Posts: n/a
i'm trying to work more upon the reliable side. i am definately going to tune it once i get everything i need in there. last project before i sell it and buy a corolla or something like that. never felt anything faster than 130hp lol.
Old Oct 27, 2005 | 09:22 PM
kyle h.'s Avatar
Im running 9lbs (60 trim .48 ar) daily on a z6 with 165k on it. compression tested around 205.
It's a fun car to drive, nothing to wild, but really fun. It's in a del sol also.
Old Oct 27, 2005 | 09:24 PM
kyle h.'s Avatar
Default Re: Where all the SOHC boosters at? (kyle h.)
only bad thing that's happened is a broken axle at the track. driver error.
Old Oct 28, 2005 | 06:57 AM
david
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">Im running 9lbs (60 trim .48 ar) daily on a z6 with 165k on it. compression tested around 205.
what's your exact set up?
Old Oct 28, 2005 | 07:23 AM
RA166E's Avatar
Theres alot of people running this kit on the http://www.turbod16.com/ forums.
Old Oct 28, 2005 | 07:37 AM
david
Guest
Posts: n/a
Default Re: Where all the SOHC boosters at? (RA166E)
thanks dude...
Old Oct 28, 2005 | 12:34 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RA166E &raquo;</TD></TR><TR><TD CLASS="quote">Theres alot of people running this kit on the http://www.turbod16.com/ forums. </TD></TR></TABLE>
or SOHChonda.com
Old Oct 28, 2005 | 02:19 PM
cody@cgracing's Avatar
you dont need head studs i have stock head bolts in my motor making over 400 hp.
Old Oct 28, 2005 | 05:30 PM
USDM 4G VTEC's Avatar
Default Re: (11secsohc)
im here as well
Old Oct 28, 2005 | 08:31 PM
EnzoSpeed's Avatar
Default Re: (USDM 4G VTEC)
Damn 11secsohc, where the heck have you been hiding? 400whp is pretty impressive on a stock head.
Old Oct 28, 2005 | 08:50 PM
Jdm_Ek_Hatch's Avatar
Default Re: (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Damn 11secsohc, where the heck have you been hiding? 400whp is pretty impressive on a stock head.</TD></TR></TABLE>
And especially stock head bolts
Old Oct 29, 2005 | 05:46 PM
dornon13's Avatar
Default Re: (Jdm_Ek_Hatch)
WE ARE EVERYWHERE!!
and if im not mistaken we are referred to as ninjas
Old Oct 29, 2005 | 07:05 PM
rainmanef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11secsohc &raquo;</TD></TR><TR><TD CLASS="quote">you dont need head studs i have stock head bolts in my motor making over 400 hp.</TD></TR></TABLE>
What is your setup?
Old Oct 29, 2005 | 07:51 PM
nota-eg's Avatar
Default Re: (rainmanef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanef &raquo;</TD></TR><TR><TD CLASS="quote">What is your setup?</TD></TR></TABLE>
Word.
Z6 w/ 230k+ on the block, bone stock
TD04 14G (Yes, 14G)
JRC 6" FMIC
Uberdata- semi-tuned
7psi daily driven w/ a horrible oil leak.
No where near fast enough, but much better than stock.
Old Oct 29, 2005 | 11:18 PM
LoSt is BlaCk's Avatar
Default Re: (nota-eg)
checking in
the greddy kit will do what you need
Old Oct 29, 2005 | 11:37 PM
Timmay's Avatar
he made that power on
rods/pistons and a sc61
tuned by cortney green on hondata
Old Oct 30, 2005 | 07:12 AM
dornon13's Avatar
Default Re: (Timmay)
I guess ill list mine since i already typed it up
98 civic coupe
D16y8 stock everything
T3 super 60 .48 exhaust
tuner toys 450cc inj.
Walbro 255
Crome
Greddy profec B spec II BC
plx m300
tial 38mm
turboxs rfl
max rev manifold
johnny race car 6" intercooler
2.5" IC piping
2.5"downpipe/cutout/stock exhaust
no cat
full weight
ran 9.3s 2.4 60ft slipping clutch 11psi open downpipe
video: the guy taping missed the launch...too bad lol 2.4s http://etrackmasters.com/modul...n.avi divx codec
dyno: 8psi stock exhaust 187whp http://www.etrackmasters.com/dyno/chrisdor.gif
Old Oct 30, 2005 | 08:18 AM
thanks timmay
Old Oct 30, 2005 | 07:34 PM
rainmanef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">he made that power on
tuned by cortney green on hondata</TD></TR></TABLE>
Thanks. At what psi did you make 400whp? Can you give some more details?
