when is it necessary for an upgraded fuel pump?
Old May 13, 2002 | 04:30 PM
ceemarun's Avatar
Default when is it necessary for an upgraded fuel pump?
the situation is a greddy kit, boosting only 7.5psi. will have a hondata stage 2b soon. how necessary is an upgraded fuel pump?
Old May 13, 2002 | 04:32 PM
Sonny's Avatar
Default Re: when is it necessary for an upgraded fuel pump? (ceemarun)
You need to upgrade the pump whenever your fuel pressure will exceed about 60 psi. The B series and H series pumps have a check valve in them that will limit their max fuel pressure to 75 psi. At 60 psi, the pump takes a pretty steep nosedive in efficiency and flow output.
So even if your FMU is trying to hold 90 psi (that is a very common pressure with an FMU) in the fuel rail, the pump will only deliver 75 = kaboom.
Sonny
Old May 13, 2002 | 05:18 PM
ceemarun's Avatar
Default Re: when is it necessary for an upgraded fuel pump? (Sonny)
any suggestions as to cheap/efficient in-tanks?
Old May 13, 2002 | 06:04 PM
SiRkid's Avatar
walboro, holley, etc same ****
Old May 14, 2002 | 01:39 PM
dc r-spec's Avatar
Default Re: when is it necessary for an upgraded fuel pump? (SiRkid)
get an inline pro one,(703)-644-1788, they are good ones
SIK IN DA HED
Nov 12, 2003 09:37 AM
Pfieff
Oct 20, 2003 12:56 PM
wrXtian
Jan 20, 2003 07:49 AM
zojirushi
Sep 30, 2002 11:00 AM
5gen-hybrid
Aug 5, 2001 10:17 AM
