When does the AFC lose it's memory ?
Old Apr 6, 2004 | 03:36 PM
X2BOARD's Avatar
Default When does the AFC lose it's memory ?
If I were to disconnect the ignition power or ground wire from a 'tuned' afc.... will the settings be retained... or will I need to do the setup/tuning again ?
Old Apr 6, 2004 | 03:37 PM
MikeMAN's Avatar
Default Re: When does the AFC lose it's memory ? (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">If I were to disconnect the ignition power or ground wire from a 'tuned' afc.... will the settings be retained... or will I need to do the setup/tuning again ?</TD></TR></TABLE>
settings will be retained due to the onboard eeprom design
mike
Old Apr 6, 2004 | 03:44 PM
X2BOARD's Avatar
Default Re: When does the AFC lose it's memory ? (MikeMAN)
So when does it lose the memory or what would cause it to clear ?
Or is it like a flash memory ? (no need for power to retain mem.)
Old Apr 6, 2004 | 03:45 PM
AzG35's Avatar
The only time a Apexi AFC "should" lose its memory is when you initialize all the settings in the ETC menu.
Old Apr 6, 2004 | 03:48 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">So when does it lose the memory or what would cause it to clear ?
Or is it like a flash memory ? (no need for power to retain mem.)</TD></TR></TABLE>
Precisely, it stores them until you delete them. Think of how many guys would be writing down their settings I am constantly un-doing my battery when im doing wiring.
mike
Old Apr 6, 2004 | 03:51 PM
X2BOARD's Avatar
Whew....kewl...
So when I plug in this unit I bought... it should already have settings even after sitting for so long.
Good to know...even tho I need to re-initialize it anyways.
Old Apr 7, 2004 | 03:22 PM
X2BOARD's Avatar
Can anyone tell me why there are 2 ignition power wires on there ?
Old Apr 7, 2004 | 03:37 PM
AzG35's Avatar
One is probably to power the unit and the other is to send power to the VTEC solenoid at the set VTEC engagement.
civc_tt
Aug 13, 2006 07:33 PM
jones50000
Jun 18, 2006 07:42 AM
b18ctrb
Jan 18, 2006 08:48 AM
{Powered by VIII}
Apr 23, 2005 03:33 AM
henryicecold3000
Jun 16, 2004 12:13 PM
