Whats wrong with this pic???
Old May 9, 2004 | 07:42 PM
TurboGSR00's Avatar
Default Whats wrong with this pic???
So i was ran someone last night and this is what happened.......
Wideband was hooked up and ran 12.1 a/f and temp was fine........ dont know what caused this to happen.... I was running 15psi ... JE pistons and eagle rods.... The piston and valve burnt up on #3 Cylinder... Any ideas??
Old May 9, 2004 | 07:45 PM
Turboteggy's Avatar
Default Re: Whats wrong with this pic??? (TurboGSR00)
I feel your pain brother.......
Old May 9, 2004 | 07:46 PM
MikeMAN's Avatar
hmm, what running was tapped for your EGT?
mike
Old May 9, 2004 | 07:50 PM
DIRep972's Avatar
Smarter than you
Probably were running too much timing and you detonated.
Old May 9, 2004 | 07:52 PM
MikeMAN's Avatar
Default Re: Whats wrong with this pic??? (DIRep972)
yea, that valve + piston definately aren't "burnt up" they are EXPLODED up (detonation)
mike
Old May 9, 2004 | 07:57 PM
11psiTurboSI's Avatar
Default Re: Whats wrong with this pic??? (MikeMAN)
ouch!!!
TurboGSR00's Avatar
O2 sensor was welded into the downpipe for the wideband... Ran perfect for a year tuned like this...
Old May 9, 2004 | 08:04 PM
Tinker219's Avatar
Default Re: (TurboGSR00)
Until a bad drop of gas entered the cylinder
Old May 9, 2004 | 08:31 PM
FOrSfEd's Avatar
Default Re: (Tinker219)
Damn Harry I heard about that. Hope yourable to get it back on the road soon.
Old May 9, 2004 | 08:35 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Until a bad drop of gas entered the cylinder </TD></TR></TABLE>
yea, thats all it takes
Old May 9, 2004 | 10:29 PM
LBR92DA-T's Avatar
kinda looks like my #4 piston when i blew.. hope things work out... is your motor sleeved or just stock sleeves?
Old May 9, 2004 | 11:39 PM
dasher's Avatar
Whats your fuel management?
Old May 10, 2004 | 05:18 AM
RTE117's Avatar
Burnt valve.. Ouchies
Old May 10, 2004 | 05:35 AM
FOrSfEd's Avatar
Default Re: Whats wrong with this pic??? (IDriveAHonda)
It's a Benson sleeved block, and he is running a hondata s200b with I believe 720cc injectors.
Old May 10, 2004 | 05:42 AM
Dr Pooface's Avatar
Default Re: Whats wrong with this pic??? (FOrSfEd)
Injector failure?
Old May 10, 2004 | 05:45 AM
dasher's Avatar
Did you rev your car really high when this happened ???
Old May 10, 2004 | 06:12 AM
TurboGSR00's Avatar
Default Re: Whats wrong with this pic??? (dasher)
I ran it to 7k RPMS in 5th gear at about 150......... they are 740cc
Old May 10, 2004 | 06:19 AM
vaporboy12's Avatar
thats a lot of load on the motor!!!
dasher's Avatar
hmmm , i was thinking valve float - but 7k is really not that high... I would check those injectors and see if one of them siezed/// do you remember where which gas station you bought your gas from?
Old May 10, 2004 | 06:23 AM
dasher's Avatar
Default Re: (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">thats a lot of load on the motor!!!</TD></TR></TABLE>
... I agree .. 5th gear pulls on the highway at 150 mph do put alot of stress on the engine...
were you doing extended 5 th gear pulls repeatedly or did you simply do one throttle blip on the highway?
Old May 10, 2004 | 06:39 AM
TurboGSR00's Avatar
Default Re: (dasher)
It was 2 pulls of 150........... I got gas from sunoco......Injector was fine.... If it heated up so much wouldnt the other ones be messed up too..???
Old May 10, 2004 | 07:00 AM
DD_JonnyLee's Avatar
damn, that sucks
Old May 10, 2004 | 07:05 AM
m R g S r's Avatar
Default Re: (GitrDone)
Are the cylinder walls scratched? If not, just give it a light hone and throw in a new piston. Are those stock valves?
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGSR00 &raquo;</TD></TR><TR><TD CLASS="quote">It was 2 pulls of 150........... I got gas from sunoco......Injector was fine.... If it heated up so much wouldnt the other ones be messed up too..???</TD></TR></TABLE>
Not really. Not all four cylinders will blow simultaneously...one will fail then it's all over.
MiraiZ's Avatar
ooo ouch!
Just a guess...but I don't think detonation is always semetrical and even across all cylinders. I only blew one piston...the other three were perfect...
