What's my setup good for?
Old Oct 22, 2003 | 06:06 AM
Hoosier Daddy's Avatar
Default What's my setup good for?
Hey guys, just wondering what I could expect out of my setup. I know a lot of it has to do with tuning, conditions, etc. but a ball park range would be nice. I have a 99 LS block that's being treated to CP Pistons and EF-1 Rods. About how much will I be able to boost on that with some good tuning? I'm not looking to go crazy, I'd honestly be happy with 10psi, but it would be nice to know about how much this setup could handle.
What tuning method would you recommend? I'm leaning towards Hondata because it's good and affordable. Which Hondata would you go with? Right now, all I have is SAFC/DSM injectors/chipped ECU (retards 1 degree of timing/psi). It's worked fine on my B20 @ 6psi (see sig for #'s). I figure I will use this in the beginning and run 6psi, but I'd like some tuning for 8+
The rest of the motor is basically stock except for EF-1 L28 cams, Skunk2 cam gears, and Skunk2 intake manifold.
One more question, are there any decent tuners around here? I'm from NY but don't mind traveling to NJ/CT/PA/MA (any surrounding areas) for some good tuning.
Sorry about the long post, it's getting closer, and I'm getting anxious to know how my setup will perform
Old Oct 22, 2003 | 11:22 AM
Default Re: What's my setup good for? (Boost Creep)
Old Oct 22, 2003 | 05:42 PM
Phaze2 Mike's Avatar
bump for this fool
Old Oct 22, 2003 | 05:53 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Phaze2)
720 cc injectors and hondata s100...i think with pistons/rods you would be safe with 375-400whp, PSI woul depend on your turbo size, etc...
Old Oct 22, 2003 | 05:57 PM
m R g S r's Avatar
Default Re: (Mpir3)
I'm pretty sure your stock LS would have been able to handle 10psi tuned, maybe even 12. Yea about 350whp sounds right.
Old Oct 22, 2003 | 07:18 PM
Much more than I expected
Stock walls will be fine with 350-400whp?
Old Oct 23, 2003 | 01:47 AM
TurboJesse
Guest
Posts: n/a
people have made over 500 with stock sleeves...its all in the tuning and if you wanna push it..
Old Oct 23, 2003 | 04:19 AM
ekb18c's Avatar
hondata is the way to go.
Yes, you can make tons of power on stock sleeves it's just that your tuner will have to do a good job on your car.
The only way to find out what your setup can handle is to goto the dyno and try it because every motor is different.
Old Oct 23, 2003 | 04:52 AM
Default Re: What's my setup good for? (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">hondata is the way to go.
The only way to find out what your setup can handle is to goto the dyno and try it because every motor is different.</TD></TR></TABLE>
You guys have a dyno at RPM don't you? If not, do you know of any good tuners in the area?
supersilverdc2
Mar 27, 2015 04:02 PM
redDAinteg
Jun 19, 2005 09:02 AM
rough_draft
Apr 10, 2004 10:29 AM
ThEOutSidEr
Feb 29, 2004 04:59 PM
FroggyR
Apr 21, 2002 03:54 PM
