whats a good plug gap
Old May 13, 2005 | 03:10 PM
forcefedh22's Avatar
Default whats a good plug gap(h22 turbo)
I have an h22. I am running about 6 pounds on a t3/t4 turbo. Its breaking up a little around 4500-5500rpms when I turn the boost to 8psi, Its really bad I'm pretty sure its ignition related, anyone know what a good plug gap setting would be?
arf is 12:1 all the way across the board.
Modified by forcefedh22 at 7:26 PM 5/13/2005
Old May 13, 2005 | 03:32 PM
dustin's Avatar
Default Re: whats a good plug gap(h22 turbo) (forcefedh22)
Just keep dropping the gap until it goes away... try .025"
Old May 13, 2005 | 03:41 PM
TurboGoKart's Avatar
Default Re: whats a good plug gap(h22 turbo) (dustin)
Yeah, anything around .030 is good. What is it gapped at right now?
Old May 13, 2005 | 03:57 PM
Default Re: whats a good plug gap(h22 turbo) (TurboGoKart)
.035, it was ok untill I got it tuned, My first run I made 257hp 216.6 torque the arf went off the board a couple of times, It was way off. when I got it set to normal the hp was 281 and torque 245.7 and it started too run like **** then,I figured the more hp i ran the smaller i had too make the gap am I right?
Old May 13, 2005 | 04:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedh22 &raquo;</TD></TR><TR><TD CLASS="quote">.035, it was ok untill I got it tuned, My first run I made 257hp 216.6 torque the arf went off the board a couple of times, It was way off. when I got it set to normal the hp was 281 and torque 245.7 and it started too run like **** then,I figured the more hp i ran the smaller i had too make the gap am I right?</TD></TR></TABLE>
That's correct. It may be that your stock ignition system needs some help. But I'd start with the cheaper things first and try closing the gap a little.
Old May 13, 2005 | 04:10 PM
dustin's Avatar
h22 ignition kinda sucks so you usually have to gap them pretty tight...
Old May 13, 2005 | 04:24 PM
ok thanks for all your help.
95teilhatch
Sep 30, 2007 09:15 PM
The Weather Man
Feb 10, 2006 06:10 AM
high_revs
Oct 30, 2005 01:01 PM
hondaapi
Oct 2, 2004 02:04 AM
berkel
Jul 12, 2001 08:28 AM
