Whats the Differences ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">Smaller turbos move less airflow per pound of boost. Bigger turbos move more air per pound of boost. Airflow makes power. Boost is a measure of restriction. Think about it.</TD></TR></TABLE>
That is quite possibly the best description I've ever heard
Good, yes...but a reply which Civic Sir probably doesn't understand.
In other words....it depends on ALOT of factors. How much boost? What sized engine? To what RPM will you be taking this engine? Blah, blah, blah.
What it comes down to is turbo efficiency. If you have a turbo spinning REALLY fast to try and keep up with your boost requirements for x rpm and an x sized engine....its going to produce ALOT of heat. Hot air = not good due to it being less dense. The point of turbo charging is to cram more air into your engine.....if you are boosting say 15 psi on a small turbo up to 8000 rpms on a 2 liter its gonna be pushing a lot of hot air because its out of its efficiency range. If however you use a larger turbo, it works less to do the same (within its efficiency range hopefully) and pushes cooler (more dense) air and producing more power.
That sounds about right. Does that make sense at all civic cir? If anyone has something to add...feel free. Thats all I've got, I'm still learning.
RTW DC2R
Nov 17, 2006 03:19 PM
