What wastegate to get?
Old Aug 27, 2003 | 07:40 PM
Neukin's Avatar
Default What wastegate to get?
im wanting to run anywhere from 16-22psi im thinking, you know turn it down when not racing around, but i guess it would never really be changed, i dont know. what wastegate should i get, is the 35 or 38mm tial one ok?
Turbocivic94's Avatar
Default Re: What wastegate to get? (toyosupr)
38 mm
Old Aug 27, 2003 | 07:46 PM
Neukin's Avatar
Default Re: What wastegate to get? (25 PSI CRX)
works for me. thanks
Old Aug 27, 2003 | 07:47 PM
drvfast's Avatar
tial 38mm
Old Aug 27, 2003 | 07:55 PM
Neukin's Avatar
Default Re: What wastegate to get? (drvfast)
so how do i set it for 20-22 psi do i have to get a large blue and small blue spring or what, how does the whole spring thing work?
Old Aug 27, 2003 | 08:19 PM
Infinity_Racer's Avatar
The spring is the lowest psi you can set it to...you can get a lower psi rate of your actual "goal" and get a boost controller to "up" the boost...
there's a thread in the archives that has all the spring rates for the tials... HTH
Txdragon
Feb 24, 2018 03:03 AM
pcguy760
Jul 8, 2011 09:08 AM
_Cyclone_
May 4, 2005 02:32 PM
b18-c-rx
Feb 22, 2005 06:52 PM
B00ST2nR
Nov 3, 2004 11:39 AM
