what type of turbo should be good?
Old Sep 21, 2007 | 12:55 AM
killingtwobirds's Avatar
Default what type of turbo should be good?
hi i was wondering what type of turbo should be good in making good power and fast spool for my h22 planning to try make 500hp??
Old Sep 22, 2007 | 04:24 PM
prelude2perfect's Avatar
Default Re: what type of turbo should be good? (killingtwobirds)
if youre willing to drop the cash, i would go for a gt30r or a gt35r
Old Sep 24, 2007 | 09:27 AM
ah okay thanks for the help iam kinda of a noob at picking what kind of turbos thanks.
Old Sep 24, 2007 | 09:44 AM
Schister66's Avatar
Man U FTW
for half the cost, you could use an SC61
Old Sep 24, 2007 | 10:20 AM
morgan@synapse motorsport's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">for half the cost, you could use an SC61</TD></TR></TABLE>
300 dollars less is not half the cost.
i also suggest a gt3076r. if you want room to grow gt35r.
Old Sep 24, 2007 | 10:32 AM
Default Re: (mike@synapse motorsport)
i have a h22 prelude and Im most likely going with a gt3076r for a good street setup. It all depends what youre looking for. If you plan to go over 500 say for the strip then I would get the gt35r like mike said for room to grow. If its mostly for a street setup I think the gt3076r is plenty enough power for a h22. Not sure what A/R trim though, maybe someone else can help you with that
Old Sep 24, 2007 | 05:44 PM
is the gt35r bigger than the t60? and if its alot bigger than the t3t4 turbos?
Old Sep 24, 2007 | 07:38 PM
the gt35r is a 61mm turbo its quite a bit bigger than a t3/t04e but some t3/t4 turbos have the same compressor wheel ie the blowzilla.
Old Sep 25, 2007 | 02:00 AM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">
i also suggest a gt3076r. if you want room to grow gt35r.</TD></TR></TABLE>
Old Sep 25, 2007 | 07:54 AM
TTT's Avatar
TTT
Have you looked at the Borg Warner turbos?? I would have to take a look at a S362 with a T3 .70 A/r 3" V-band turbine housing. IT has made over 650whp on race gas and 500whp on pump gas. It spool about the same as a GT35R.
Old Sep 25, 2007 | 08:18 AM
maxheat's Avatar
Can you fit the GT30r on a b18c without shaving the block webbing?
1fastlude1
Aug 28, 2013 01:22 PM
jetlude
Oct 10, 2007 06:03 PM
Dr. Jay
Mar 23, 2007 11:56 AM
v-tec maz
12
Nov 11, 2005 08:12 PM
98lude-t
Nov 28, 2004 10:19 PM
