What is this sound? video,
Old Jun 5, 2009 | 10:56 AM
kauai96's Avatar
Default What is this sound? video,
what is this sound? vaccum leak??? i dont know im pretty stumped. shitty video listen to the sound right when i start to open the throttle sounds like almost like the time is super retarded, like its bouncing off the 2step but its not. but similar sound. what is it?
Link to vid : http://s234.photobucket.com/albums/e...5090843-00.flv
Old Jun 5, 2009 | 11:23 AM
92EGminihatch's Avatar
Default Re: What is this sound? video,
sounds like a computer problem for sure. something with the ecu. almost sounds like a rev limiter or something. but i have no idea. just guessing. lol. just a bump so someone who maybe knows better can give you some help.
Old Jun 5, 2009 | 11:54 AM
kauai96's Avatar
It did this with the stock ECU as well, i just replaced it with a phearable.net p28, it some how helped the sound. like before it last from like 2600 all the way to like 3300rpms. now it stops at like 2800-3000rpms. thanks for the bump though! help.
Old Jun 5, 2009 | 12:05 PM
FastEg6's Avatar
More info on the setup? What's it tuned on? Injector size? We need more info in order to help you out here.
Old Jun 5, 2009 | 12:10 PM
kauai96's Avatar
D16/d15 head non VTEC, Phearable.net Chipped p28 running the base map, 440cc injectors, t3/t4 turbo,3" downpipe, 2.5" Charge pipe, walboro 255, Open dump Turbo XS wastegate. built head, Stock cam.
Old Jun 5, 2009 | 02:15 PM
kauai96's Avatar
bump still need help
Old Jun 5, 2009 | 03:37 PM
omgwtfbbq's Avatar
any CELs?
Old Jun 5, 2009 | 04:53 PM
kauai96's Avatar
yeah it wasnt what i had expected, its throwing a Code 14 (IAC), any thoughts?
Old Jun 5, 2009 | 04:59 PM
omgwtfbbq's Avatar
change the valve. If it helps, you'll know right away.
Here's something I read up on someone with the same symptoms as you.
http://www.civicforums.com/forums/17...iac-valve.html
auuu riiiiiite!
Old Jun 5, 2009 | 05:18 PM
FastEg6's Avatar
Change out the IAC, see if that helps. Also get it tuned before you mess something els up and run into more problems.
Old Jun 5, 2009 | 05:32 PM
phatrick2332's Avatar
Just clean the IAC before you go get a new one, it may fix your problem.
Old Jun 5, 2009 | 06:07 PM
kauai96's Avatar
that link to civic forums, those are the exact symptoms that my car has, im thinking vaccum i have been checking and double checking everything today i went in and adjusted the IAC it got better but its still there just not as violent. im thinking the vacume lines for the BOV ,boost gauge ect. right now i have them on plastic T fittings. I think i'm going to look in to vaccum distrubution block. Any other theories anybody?
Old Jun 5, 2009 | 09:59 PM
omgwtfbbq's Avatar
I have plastic Tee fittings on my setup and they hold the vaccuum good. I would be more concerned about the IAC since that's the DTC that you are getting.
Old Jun 6, 2009 | 09:50 AM
integralactic's Avatar
Looking at the video looks like you are still using the original DX manifold with the 3 wire IAC. OBD1 ECU will not run the 3 wire IAC. You should convert to AN EX manifold with the 2 wire IAC and rewire it. Also you should get it tuned.
Old Jun 6, 2009 | 10:35 AM
kauai96's Avatar
right on it makes sense, would the d15 mani work? im also working on getting it tuned
Old Jun 16, 2009 | 02:36 PM
kauai96's Avatar
Now i was wondering, could it be the MAP sensor, its a stock MAP, im looking t a 2 bar or somthing
Old Jun 16, 2009 | 02:41 PM
omgwtfbbq's Avatar
going to a higher bar map sensor is onyl necessary if you plan on going beyond 12 psi (what hondas stock map sensor can handle).
however, a faulty map sensor could cause your throttle problem.
you can check the voltage @ the sensor to determine if it is good. i dont remember how, but the manual should say. i'd also check out that IAC.
Old Jun 16, 2009 | 03:12 PM
ndondahows's Avatar
sometimes people hook up map and tps sensor backwards. could make you run like that. switch em up. also if your ecu was set for a differnt than stock map it could do that. definately is a map issue of some sort
Old Jun 17, 2009 | 09:58 PM
kauai96's Avatar
Yeah i do have a different MAP in my ecu but the stock ecu does the same thing. Im not pretty sure i hooked all the sensors up right. i got the manual so ill test the voltage tomorrow after work. Any other suggestions in the mean time?
Old Jun 18, 2009 | 01:11 AM
NLR808's Avatar
Yea just try switching the plugs
I'm actually going to Kauai this weekend but my tuning laptop is having issues and won't connect to the Internet so my darn ectune is locked since I missed an update
But I'd be down to take a look at it pm me
Old Jun 18, 2009 | 08:00 AM
cockerkid008's Avatar
Fix the CEL and get the car tuned
Old Jun 18, 2009 | 08:16 AM
jdm inc's Avatar
sound like the ecu is in limp mode. Thats just my guess. You should also look into what integralactic said about the 3 wire iac to a 2 wire iac. and also get it tune.
Heres katmans write up pretty good info.
http://www.ff-squad.com/technet/
Old Aug 30, 2009 | 02:52 PM
kauai96's Avatar
thanks boys, i just got back on the internet. ha i just finished up my supercharged tacoma so i can use it as a Daily. now its back to the car. im gunna try that iac fix
serdarg
Mar 28, 2013 06:17 AM
01nhbgsr
Acura NSX
May 5, 2004 05:19 PM
TurBoXBirD16
Feb 20, 2003 06:57 AM
