What size turbo?
Old Mar 2, 2002 | 03:53 PM
InfamousRS's Avatar
Default What size turbo?
Once again I have changed my mind on a turbo setup. I may try to get in on the turbo group buy, then peice the ket together with the parts I want.
Anyways, I will be runnning the turbo on a stock b18b for now. In the furture, I plan on a b18b block, Golden Eagle sleeves(84mm or 85mm bore), Je pistons, eagle rods, and a Vtec head.
On my stock block, I will run no more than 10 lbs of boost, with hondata of coarse. Im not sure how much I want to run when I have a built block.
What compressor trim & exhaust a/r would work well now and when I have a built engine? Here are the trims offered to my knowledge:
compressor trim: .50, .54, .57
exhaust a/r: .48 or .63
Thanks for any info.
[Modified by BLK94RS, 2:06 AM 3/3/2002]
Old Mar 2, 2002 | 04:02 PM
falcongsr's Avatar
What is this crap?
Default Re: What size turbo? (BLK94RS)
stock redline or ?
Old Mar 2, 2002 | 04:05 PM
InfamousRS's Avatar
Default Re: What size turbo? (falconGSR)
7000 RPM redline with my stock motor, not sure with built motor.
Old Mar 2, 2002 | 05:04 PM
InfamousRS's Avatar
ttt
Old Mar 2, 2002 | 06:56 PM
InfamousRS's Avatar
What do you guys think of this:
Compressor trim: .57
Exhaust a/r: .63
That is what FFGeoff used to run 12.0 with his stock b18b. Would there be alot of lag with that big of a turbo with a stock b18b (7000 rpm redline)?
Also, is 10 psi 10 psi no matter what size of a turbo? Would I make more power with a larger turbo?
[Modified by BLK94RS, 3:57 AM 3/3/2002]
Old Mar 2, 2002 | 07:12 PM
cyan1de's Avatar
a larger turbo will make more power at the same amount of boost, because it is flowing more air.
Old Mar 2, 2002 | 07:14 PM
falcongsr's Avatar
What is this crap?
Exhaust a/r: .63
at this point, that might be your best option. hold out til monday, we should have more answers then
Old Mar 2, 2002 | 07:52 PM
InfamousRS's Avatar
Thanks falcon! I'll know within 2 weeks if I will beable to get in on this. I sure hope everything works out!!!!
Anyways, do you guys think I would hit full boost before 4000 rpms?
Here is my planed setup:
Stock b18b
Skunk 2 cam gears
ClutchNet stage 2
ITR flywheel
Hondata 2b
DSM 450 injectors
Walbro fuel pump
MaxRev manifold
MaxRev full 3" DP
MaxRev 20x8x3 inch IC
"Custom" do-it-myself piping
HKS Super Sequential BOV
Tile 35mm WG
Turbo XS High Performace MBC
Thermal 3"
I probably lest somthing out, but I got the basic stuff down.
[Modified by BLK94RS, 8:54 PM 3/2/2002]
Old Mar 2, 2002 | 08:54 PM
BlueShadow's Avatar
Default Re: What size turbo? (cyan1de)
what he said, and to give you an example:
10 PSI on a straight T3
10 PSI on a T4/T3
obviously a lot of "power" is lost in the T3's due to it's "restrictive" size....or something like that.
cilvercivic
49
Sep 27, 2010 04:59 AM
PhatBoy5015
Jan 4, 2006 12:17 PM
The Civic Project
Dec 29, 2004 02:19 PM
Ls1 FD3s
Dec 15, 2004 08:02 PM
skunk2eg
Jun 10, 2004 07:06 PM
