what size is t25?
Old Aug 28, 2005 | 11:31 PM
weak_sauce's Avatar
Default what size is t25?
Im going to buy a turbo kit soon and the description said t25 turbo size, what size is that exactly? is it bigger than the greddy 18g turbo? or is it smaller? compare size to t3/t4 etc ...any info will help me, thanks
Modified by weak_sauce at 12:57 AM 8/29/2005
Old Aug 29, 2005 | 01:52 AM
90LSpimpin's Avatar
Default Re: what size is t25? (weak_sauce)
Tiny. Good for a sohc if your lookin for quick spool, but not if your lookin to be a HP *****. It'd hit full boost by like 2500 on a bseries.
Old Aug 29, 2005 | 07:22 AM
tilt's Avatar
if you are referring to the dsm t25, it's roughly between a IHI-RHb5 turbo and a small T3
Old Aug 29, 2005 | 08:22 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: what size is t25? (tilt)
what motor is it going on??
Old Aug 29, 2005 | 05:17 PM
weak_sauce's Avatar
what is it compare to the greddy 18g turbo? prolly on a b series? but im just asking what size is it? how much power would it make?
Old Aug 29, 2005 | 05:57 PM
JalopySiR's Avatar
Default Re: (weak_sauce)
If it is a straight T25 (T25 compressor), then it is smaller than an 18G(compressor)
You wouldn't happen to have any of the specs of the turbo in question, would you?
If it is a straight T25, then I would pass, esp. on a B-series engine.
I also went with a T28 (60trim T3 compressor) on a B-series, so I'm not talking without experience.
Old Aug 29, 2005 | 08:43 PM
rkrone's Avatar
t25 is found on eclipse and sr20det, they are very small, stock 7 psi, max around 15 psi
Old Aug 29, 2005 | 11:13 PM
Cray91's Avatar
standard T25 is smaller. I would suggest going larger on a B-series.
Old Aug 30, 2005 | 07:31 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Cray91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cray91 &raquo;</TD></TR><TR><TD CLASS="quote">standard T25 is smaller. I would suggest going larger on a B-series.</TD></TR></TABLE>
Old Aug 30, 2005 | 07:38 AM
Adam.C's Avatar
it really depends on what kind of power you are wanting to make. T25 has a fast spool but will not make as much power as say a t3/t4. If its going on a B series motor, I would look into getting a t3/04e or the like...
Old Aug 30, 2005 | 07:58 AM
Will SR20's Avatar
The t25 varies. The DSM t25 does not make as much power as the nissan t25. I know the nissan t25 is cabable of around 280whp on a FWD sr20 motor. They are out of thier efficiency past 14psi.
psycho_civic
Oct 16, 2003 02:41 PM
Spoold_R
Sep 12, 2003 08:13 AM
bisket
Mar 5, 2003 04:04 PM
