what size injectors do I need?
Old Jun 17, 2003 | 12:16 PM
B00STeD's Avatar
Default what size injectors do I need?
Getting a SC61 turbo w/ T04S compressor housing, going on built 2.0 gsr, looking for high 400's and low 500's on race gas. Let me know what size injector I need.
Old Jun 17, 2003 | 12:59 PM
pissedoffsol's Avatar
25 Year Member
Default Re: what size injectors do I need? (B00STeD)
860's ish should cover you
Old Jun 17, 2003 | 01:17 PM
PrecisionH23a's Avatar
Default Re: what size injectors do I need? (pissedoffsol)
http://www.rceng.com/technical.htm
Old Jun 17, 2003 | 02:24 PM
B00STeD's Avatar
Default Re: what size injectors do I need? (GudeH23a)
it says I need 550's???? Not right at all, anybody elese want to help me??
Old Jun 17, 2003 | 02:41 PM
thats because you probably entered in 400 CRANK horsepower. add 15% to your wheel horsepower goal to achieve crank horsepower. to do this, multiply 1.15 X WHP
Old Jun 17, 2003 | 03:32 PM
The Crow's Avatar
1100cc injectors with 45psi of fuel pressure for 500 crank HP.
Old Jun 17, 2003 | 05:39 PM
B00STeD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">thats because you probably entered in 400 CRANK horsepower. add 15% to your wheel horsepower goal to achieve crank horsepower. to do this, multiply 1.15 X WHP</TD></TR></TABLE>
NO! actually I entered 575 CRANK horsepower just messing around but it gave me that dumb answer.
Old Jun 17, 2003 | 05:48 PM
EVIL_AWD's Avatar
If you entered 575 crank horsepower as your desired power level, then you didn't enter the rest of the equation correctly. With 575 crank hp, .60 B.S.F.C. and 45 psi of fuel pressure RCE's calculator says you will need 1100cc/min. fuel injectors which will be operating at 80% cycle duty.
Old Jun 18, 2003 | 11:06 AM
Kataku2K3's Avatar
Default Re: what size injectors do I need? (ITR420)
On Brian's B18C/EJ6 we run 990's on 22lbs of boost and a static FP of 38psi... It made 536whp the other day and ran a shitty *** 11.11@132 (traction sucks now)... I say somewhere around that, we're actually going to run 1200's then Duc's street car is going to run 1600's... That's with an SC63 or 67 and ~28lbs... Good Luck and let us know how it goes... Peace
raverx3m
May 30, 2014 10:35 PM
ral24_hct
Jul 26, 2010 04:40 AM
4thgenHB157
Sep 23, 2008 08:08 PM
SlammedCD7
Jan 8, 2005 07:28 PM
iv
Mar 24, 2003 04:35 PM
