what size freeze plug for b16 engine
Old Dec 21, 2006 | 07:23 PM
Nordy's Avatar
Default what size freeze plug for b16 engine
i bought an endyn catch can used but it didnt come with the freeze plug....i have to go to auto parts and buy it but i dont know the size....i searched but couldnt get a straight answer....some people say 34.3mm and some say 34.6.....does anyone know for sure what size freeze plug i need for a b16 on a 2000 si? thank you, your help will be much appreciated....
Old Dec 21, 2006 | 09:40 PM
93turbo16's Avatar
Default Re: what size freeze plug for b16 engine (Nordy)
Go in to Adavanced Auto. They have a box of freeze plugs in metric sizes. Pick the one that is between 34 and 35. Fits like a glove.
Old Dec 22, 2006 | 05:11 AM
Nordy's Avatar
sweet ill go there today.....
Old Dec 22, 2006 | 10:38 AM
Nordy's Avatar
went to advance auto parts and they have a kit which bring a couple of different sizes but the sizes were all in inches....they had 1 - 5/8, 1 - 1/2 and up......after converting it to mm it was too big....so i got a 34.3 and a 35mm at napa and i got one of them expansion plugs that has the nut on the back where you tighten it and it expands in the hole for worst case scenario....it would be nice to know the exact size instead of guessing....no one has anything between 34.3 and 35 so i hope one of these work....
Old Dec 22, 2006 | 11:58 AM
93turbo16's Avatar
It should work just fine. Use some hondabond and it should seal it up. My advanced has to bins, one has plugs in mm and the other has it in inches.
Old Dec 22, 2006 | 02:50 PM
Nordy's Avatar
yeah none of the auto parts around here had anything but napa......i went to autozone, advanced, pep boys, and napa....but thats cool ill post my experience so people can look on here and use this info in case of finding themselves in the same position as me...thx
Old Dec 22, 2006 | 06:37 PM
JSpin's Avatar
Default Re: (Nordy)
even if you can't find the 34.3 or whatever it is, i've taken a 34mm plug and expanded it enough to get it to seal. kind of a pain, but i ended up using a big socket to tap into the open part of the plug.
Old Dec 23, 2006 | 04:21 AM
DaveF's Avatar
Default Re: (JSpin)
i have a z10 plug
https://honda-tech.com/zerothread?id=1831205
Old Dec 23, 2006 | 05:02 AM
DRAGLS's Avatar
Default Re: (dturbocivic)
I used 35mm on this B16a2
Old Dec 23, 2006 | 08:58 AM
Nordy's Avatar
wow...did u have to hammer the **** outta it to get it inside or was it a decent fit?
Old Dec 23, 2006 | 04:30 PM
DRAGLS's Avatar
Default Re: (Nordy)
It is a interference fit so yea I had to tap it in with a hammer. From experience almost every block uses a different size. My Ls used a 34.3. The b16 used a 35.
Old Dec 23, 2006 | 04:31 PM
alpha's Avatar
Default Re: (Nordy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">wow...did u have to hammer the **** outta it to get it inside or was it a decent fit? </TD></TR></TABLE>
Couple taps from a rubber mallet. Hope you been working out
Old Dec 23, 2006 | 04:37 PM
eddie_ek's Avatar
I used 34.3
Old Dec 24, 2006 | 09:56 PM
Nordy's Avatar
Default Re: what size freeze plug for b16 engine (eddie_ek)
****, we tried a 34.3 and ended up having to take the whole damn oil pan, oil pick up , and tray off.....it was too loose in there....put a 35mm and hammered the **** out of it until it was flush.....just got back from doing it....ha
Old Dec 24, 2006 | 10:36 PM
riceball777's Avatar
i just got the z10 plug
just call them up and order one
its $25+ shipping from z10
Old Dec 25, 2006 | 04:51 AM
Panoply's Avatar
Default Re: what size freeze plug for b16 engine (riceball777)
so no jb weld required? just held in from being taped in?
Old Dec 25, 2006 | 06:18 AM
alpha's Avatar
Default Re: what size freeze plug for b16 engine (Panoply)
Correct. The right size freeze plug taps in. It's a very tight fit
Old Dec 25, 2006 | 07:30 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Z-10 25 bux damn No one will ever see the it go to oreilly's like I did and spend 25 cents perfect fit call Larry or Josh They will give you the Dorman Part# it really is only 25 cents
Old Dec 25, 2006 | 10:24 AM
Nordy's Avatar
i spent a dollar each on 34.3mm and 35mm....the 35mm that i put in didnt seem to fit but after hammering the **** outta it, it fit perfect ....put some hondabond on the outside of it and get to hammering that beast in there....
Old Dec 25, 2006 | 06:33 PM
katoeh2o's Avatar
Default Re: (Nordy)
How would you get it out if you had to? And were do you get hondabond from. Is it like JB weld.
Old Dec 25, 2006 | 06:41 PM
alpha's Avatar
Default Re: (katoeh2o)
Drop the oil pan
Old Dec 25, 2006 | 06:45 PM
xsi-t's Avatar
u have to drop the pan remove baffle and pick up and work the plug out the galley
Old Dec 25, 2006 | 07:11 PM
HamiltonRex's Avatar
Default Re: (xsi-t)
I couldnt find ANY metric freeze plugs anywhere when i was doing my (go figure no metric in canada) anyways.. I ended up using one of the rubber ones you tighten untill it is tight, but i could only find one size way too small and another too big, so i pulled the rubber off the big one, shaved it down with a grinder, and put it back together, hammered it in the block with a mallet, then tightened her up real good. Its been good so far, its in there tight!
Old Dec 25, 2006 | 08:20 PM
Nordy's Avatar
just get a 35mm and hammer the **** out of it...after its in there i dont think itll ever come out..
Old Dec 25, 2006 | 09:02 PM
xsi-t's Avatar
Default Re: (Nordy)
hell no that **** wont ever come out un less we pull it out some how lol
