At what point is a twin scroll setup needed?
Old Oct 27, 2010 | 08:56 PM
  #26
E85B18's Avatar
Default Re: At what point is a twin scroll setup needed?
Originally Posted by Alfa Turbo
Ah, I see.
So... it's like you, the Shodan, are an *** but not all asses are you! Got it.
Get off your high horse for ALL practical purposes on this or ANY other automotive enthususiast site they ARE the same. Sure... wanna find an exception have at it but look at the big picture or head back to the college lecture hall where you can correct everyone and feel superior.
Your follow up corrective grand standing post will just certify the point. (wink)
How f*cking stupid do you feel?
Old Oct 28, 2010 | 12:49 AM
  #27
drift2004's Avatar
Haha he has anything ... Hrs like I'll just ignore the post lol
Old Oct 28, 2010 | 05:37 PM
  #28
javierb14's Avatar
Originally Posted by TheShodan
The difference? The volutes are of different sizes in which the divider goes much further down stream of the turbine inlet; not the same size as in the divided housings that are used on the larger platforms.
I'm sorry I don't have a cross-section of the two to show to give better imagery, but here's the differences in inlets themselves.
Here's the smaller twin scroll Mitsubishi inlet
Are you positive the volutes are different sizes on the EVO turbine housings? I only see the Mitsu housings listed with a single nozzle size such as 9.8cm^2 or 10.cm^2.
Old Oct 28, 2010 | 07:01 PM
  #29
TheShodan's Avatar
Moderator
that's the exterior nozzle that you're looking at, not the interior volute overall size within. That's like saying a divided .78A/R or T4 .68 housing has two A/Rs. That measurement doesn't measure the actual volute "channel" inside
9.8cm^2 and 10cm^2 is like a .68A/R and .73A/Rs in T3 "language" respectively.
Old Oct 28, 2010 | 10:52 PM
  #30
jdm95's Avatar
Ive heard of turbos using a variable inlet guide vanes, does anyone have any info on this?? Im in the aviation community and i know our jet engines use variable inlet guide vanes to change the direction of air hitting the fan blades for maximum air efficiency. I had heard they either had a turbo running this kind of setup or was in the making so you could run a larger turbo but have faster spool rates for lower end response. Im sure something like this would be quite expensive and as well need a control unit but using some of the technology that fighter jet motors use would def be cool and give you a awesome response rate across the rpm range. Im just wondering if anyone else has heard of this and can confirm or deny these types of turbos.
Old Oct 29, 2010 | 12:08 AM
  #31
slowtegkauai's Avatar
I've worked on a F-350 6.0 turbo Diesle with variable vanes on the turbine housing side. Is that what your talking about?
Old Oct 29, 2010 | 12:15 AM
  #32
SLIM NOTHING's Avatar
Originally Posted by Silva Bullit DC4
Paging Mac (Shodan) to FI room, please...
hahahaha he'll take care of it
Old Oct 29, 2010 | 05:13 AM
  #33
Schister66's Avatar
Man U FTW
Ah, I see.
Rather than reading what he has to say and learning from it, you can retain your position of ignorance. The Shodan has helped me (and others) countless times over the last few years...he has a vast wealth of info to share with us, but when comments like this are made, its no wonder that HT is starting to devolve into a forum full of half-wit teenagers.
For future reference, if you plan to make a follow-up post to this, save your breath because the "Delete Thread" button has your name on it...and thats a promise
viper_boy403
Sep 19, 2014 05:38 AM
007EG
Dec 14, 2007 04:27 PM
crucian
Dec 3, 2006 11:05 AM
falcongsr
Jan 12, 2003 12:58 AM
