what is a o-ring?
Old May 5, 2003 | 06:36 PM
qqqq
Guest
Posts: n/a
Default what is a o-ring?
what is it when you get a o-ring on your sleeves? what is its purpose? is it needed? can it be removed?
Old May 5, 2003 | 06:41 PM
inspyral's Avatar
Default Re: what is a o-ring? (babyboib16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by babyboib16 &raquo;</TD></TR><TR><TD CLASS="quote">what is it when you get a o-ring on your sleeves? what is its purpose? is it needed? can it be removed?</TD></TR></TABLE>
A groove is machined in the tops of the cylinders, and you put a copper wire "o-ring" in there to help seal them against the head.
Old May 5, 2003 | 07:09 PM
qqqq
Guest
Posts: n/a
Default Re: what is a o-ring? (inspyral)
is this needed or can it be removed. te reason i am asking is i am buying a used block and it has it in there and i want to bore it out a little more but it might be in the way
Old May 5, 2003 | 07:23 PM
qqqq
Guest
Posts: n/a
bump^^^^^^^
Old May 5, 2003 | 07:31 PM
bryan305's Avatar
It's not 'needed', but is a good preventative measure when you're putting out real power.
Old May 5, 2003 | 11:41 PM
qqqq
Guest
Posts: n/a
to the top
Old May 6, 2003 | 04:59 AM
QCKGSR's Avatar
bump
per4mance
Feb 28, 2008 12:28 PM
Golden Eagle
Oct 22, 2007 09:40 AM
86si
May 9, 2007 11:37 PM
averyvm
Jan 4, 2007 09:46 PM
