What kind of boost response....
Old Jan 20, 2006 | 10:26 PM
broketuner-Sol_Si's Avatar
Default What kind of boost response....
I was wondering at what RPM I could expect to hit full boost(7-10PSI) on a mildly modded B16A with a T3/TO4E 57 Trim .63 A/R. I think it's bigger than what I need but, I read that bigger turbos with lower boost was the way to go. It would be tuned with hondata by a professional.
Old Jan 21, 2006 | 07:07 AM
Default Re: What kind of boost response.... (broketuner-egb16a)
Forgot to mention I will be using either a blox mani. or a short tubular from LSD Motorsports.
Old Jan 21, 2006 | 08:13 AM
non-VTEC's Avatar
i would estimate full boost around 5000-5500rpm........
Old Jan 21, 2006 | 09:22 AM
Synapse's Avatar
Default Re: What kind of boost response.... (non-VTEC)
I say late spooler on the B16 with a .63 a/r. Although it depends on which .63 turbine you have, is it the Turbonetics variety? Their "Stage 3" .63 would spool up way late, but you'll want the Stage 3 for flowing the HP's later, you might want to get a spare .48 for street/road race use. That .63 will be good for drag racing.
Old Jan 21, 2006 | 09:29 AM
Default Re: What kind of boost response.... (Synapse)
No it's by garrett, a new sponsor on here is having aspecial on those specific turbos for 585 shipped.But with boost coming on so late I may not get one. I was thinking full boost by like 3500...5-5500 is pretty late IMO.
here's the link too the page.
https://honda-tech.com/zerothread?id=1499182
Old Jan 21, 2006 | 09:45 AM
Synapse's Avatar
yeah, that's a late spooler for even an 1800 CC engine, you need a .48. PM him and see if a .48 is available. Ball bearings will probably have it spool 500 RPM sooner.
Old Jan 22, 2006 | 04:42 PM
What kind of RPMs could I expect to hit full boost again 7-10 PSI with the BB option and the .48 A/R? Also Is this turbo capable of say around 300-325 HP at a higher boost level of course(That's the goal once I build up the block...till then I don't want more than 250HP.)
Old Jan 22, 2006 | 05:18 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering at what RPM I could expect to hit full boost(7-10PSI) on a mildly modded B16A with a T3/TO4E 57 Trim .63 A/R. I think it's bigger than what I need but, I read that bigger turbos with lower boost was the way to go. It would be tuned with hondata by a professional. </TD></TR></TABLE>
on my stock b16 with that turbo
makes boost at 3300rpm full boost by 4000ish
Old Jan 22, 2006 | 06:41 PM
Default Re: What kind of boost response.... (komat)
Would a smaller A/R make it spool any faster though (.48 vs.63)? I know the BB upgrade makes full boost 500-1000 rpms quicker than the same turbo without BBs.
yessewey
Feb 19, 2010 08:50 AM
onemoreday21
Nov 29, 2005 05:11 AM
DARKON
Apr 3, 2005 06:33 PM
