What Injectors are these?
Old Apr 6, 2013 | 09:23 PM
Dannyx321's Avatar
Default What Injectors are these?
I have these injectors, all i know is they are 42lb(440)
Any clue if they will fit a gsr? supposedly came out of a gsx
Will i need a resister box?
First pic reads:5208009
Second pic reads:03181AA
Old Apr 6, 2013 | 09:26 PM
TheShodan's Avatar
Moderator
Default Re: What Injectors are these?
Typical aftermarket injectors made for the DSM cars.
Yes, you'll need a resistor box.
Yes, you can reach at maximum of about 300whp at base 42.5 fuel pressure.
Yes, these are Peak/Hold injectors.
Yes, you'll have to have those o-rings and top hats modified to fit the stock B and D series fuel rail as what you have there is 14mm, and Honda uses 10mm
No, you didn't completely waste your money, but you have some work to make them fit.
GL
H
Old Apr 7, 2013 | 12:54 AM
Dannyx321's Avatar
Any suggestion on how to make them fit?
Old Apr 7, 2013 | 06:45 AM
TheShodan's Avatar
Moderator
Ironically, You send them to an injector facility to shave down the plastic and change out the o-ring to fit in the stock rail. If not, some aftermarket rails may be able to fit the 14mm o-ring for both DSM & Honda
you can send them to RC direct or Fuel Injector clinic to do it. About $40-$50. I haven't sent them in because there are facilities local to my area to get them modified.
Old Apr 7, 2013 | 06:53 AM
SiRCiviC94's Avatar
back on the market they go
Old Apr 7, 2013 | 09:16 AM
Dannyx321's Avatar
idk if this helps at all but if i take off the o rings they fit in the fuel rail, but with them on they don't, would small o rings help? like integra ones since this fuel rail is b series? (from left to ring goes o ring,no o ring,o ring,and no oring)
Old Apr 7, 2013 | 09:18 AM
TheShodan's Avatar
Moderator
GL
H
Wo-Nelly
Mar 2, 2004 07:30 AM
CRVRX
Jan 29, 2003 03:21 PM
move_right
Dec 22, 2002 07:45 AM
C-speed
Aug 23, 2001 03:21 AM
