what injector clips for precision injectors???
Old Jun 29, 2006 | 08:56 AM
.adam.'s Avatar
Default what injector clips for precision injectors???
i was told to use my obd1 clips for my 780 precision injectors, but they dont fit. it seems that there is a small tab on the injector keeping the clip from clipping in. what do you guys do? just cut off the tab on the injector? id rather not have to hack up my brand new injectors....is there any other solution?
Old Jun 29, 2006 | 10:22 AM
99B16Si's Avatar
you have to mod odb1 clips by removing the tab inside the clip
Old Jul 22, 2006 | 04:34 PM
ghettochild's Avatar
Default Re: (99B16Si)
or you can use OBD0 clips
Old Jul 22, 2006 | 08:54 PM
blackeg's Avatar
Default Re: (ghettochild)
you have to take a knife or something and cut the little tab thats inside the injector plug on the injector itself. once you do that they will clip right on. im running precision 780s with obd1 clips and thats what i did. same mod can be done with dsm injectors, etc..
Old Aug 16, 2006 | 10:39 AM
Default Re: (blackeg)
or you can not waste your time cutting on a obd1 clip and use obd0 clips they clip right up. because an obd0 injector also uses a resistor box
Old Aug 16, 2006 | 11:07 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettochild &raquo;</TD></TR><TR><TD CLASS="quote">or you can not waste your time cutting on a obd1 clip and use obd0 clips they clip right up. because an obd0 injector also uses a resistor box </TD></TR></TABLE>
it be easier and cheaper just to notch the tab inside the injector
Old Aug 16, 2006 | 11:16 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">you have to mod odb1 clips by removing the tab inside the clip</TD></TR></TABLE>
exactly what i did. even using the same injector (precision 780cc)
nix94delsol
Apr 7, 2009 02:29 AM
jchrm80
Nov 5, 2007 01:21 PM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
b18c1wes
Dec 9, 2004 02:44 PM
