This is what Im working on...input please
So I have started ordering parts for my new build.
This what I have
Head-
-94 gsr
-Blox Type Bs
-Blox Titanim Retainers
-Blox dual Springs
-Blox cam gears
-Stock vavles and guides
-skunk 2 manifold
-68mm throttle body
-omni 4 bar map
Block-
-b18b1
-wiseco 81.5mm 9:1 pistons
-eagle H rods
-ACL Bearings
-LS mirco polished crank
-golden eagle girlde kit
-golden eagle block gurad
-ARP Main Studs
-ARP head studs
-new oil, water pump
Fuel
-255 walboro pump
-750cc sat rc injectors
Turbo-
Greddy Tdo5 18g kit
blitz bov
Once I come up with more money, I will be upgrading the turbo, manifold, and downpipe
But what do you think of what I have? Possible for 300hp?
Assembly and tuning will be done in a few weeks
This what I have
Head-
-94 gsr
-Blox Type Bs
-Blox dual Springs
-Blox cam gears
-skunk 2 manifold
-68mm throttle body
-omni 4 bar map
Block-
-b18b1
-eagle H rods
-ACL Bearings
-ARP Main Studs
-ARP head studs
Fuel
-255 walboro pump
Turbo-
Greddy Tdo5 18g kit
blitz bov
The tb is just a type r that ive had for a while
I have been going off what my tuner advised for the injectors...
Im up for all other advice
many will argue that peak and hold are better especially for a turbo motor so its not just as simple as saying oh his car is set up for it so just stick with it when you can get a 15 dollar resistor box and have the car set up for peak and hold, a 70mm tb cost the same on ebay versus getting a 68mm.. i wasnt aware that he already had a 68mm throttle body.. thats a different story cus in that case it does make sense to stick with the 68mm tb otherwise no it doesnt make sense to get a 68mm tb...
the build does look sick though, good luck on it.. hope it turns out good!
https://honda-tech.com/forums/forced-induction-16/official-turbo-lsvtec-thead-post-your-setups-1509557/ (Official Turbo LS/VTEC thread)
I did 319 on 14psi, with a cheap ebay turbo and cheap cast mani from ebay, simillar set-up
i drive the car everyday, i love it. just picked up a cs addict mani and a te61 turbo, gsr cams and electronic cutout. trying for high 300's
this car is tuned on s300 with 2.5 inch dp and full exhaust no cat, tunabe muffler
b16head
type r intake mani
je dual valve springs and retainers,
b16 cams
ls block
81.5mm srp pistons
eagle h-beams
arp headstud
ls tranny
good luck on the build
b16head
type r intake mani
b16 cams
ls block
81.5mm srp pistons
eagle h-beams
arp headstud
ls tranny
319 on an ebay turbo at only 14lbs... wow.. makes you wonder how long the turbo would of lasted on 14lbs... awesome numbers for an ebay turbo though.. interesting
it can make it, but those cams will not go along well with that turbo and turbo manifold, id get stock gsr cams for now
About how long the turbo will go, i have less hen 3000 on the build and i'm changind it do to a blown center section. Car pulled good though i was happy until i figured out everyone one on ht was right about the ebay turbo.
Good luck.
Good luck.
