What Gauges Are You Running With?
Old Apr 29, 2007 | 10:15 AM
94typeR's Avatar
Default What Gauges Are You Running With?
other than wideband, oil pressure, and boost/vac
are there any other gauges that should be used with a boosted setup?
Old Apr 29, 2007 | 10:20 AM
null.'s Avatar
Default Re: What Gauges Are You Running With? (94typeR)
water temp, and maybe oil temp.
Old Apr 29, 2007 | 10:33 AM
inspyral's Avatar
I'm running boost, EGT, oil pressure, wideband, and water temp. Oil temp would be nice, and I'll probably add one when I have some extra funds.
Old Apr 29, 2007 | 10:51 AM
Bailhatch's Avatar
Default Re: (inspyral)
boost and wideband i'm ghetto i guess.
Old Apr 29, 2007 | 12:39 PM
Schister66's Avatar
Man U FTW
i only have a boost gauge....
Old Apr 29, 2007 | 01:12 PM
y7turbo's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">boost and wideband i'm ghetto i guess.</TD></TR></TABLE>
same here.
Old Apr 29, 2007 | 01:39 PM
chubz0r's Avatar
boost, wideband, water temp. i need to get oil temp as well.
Old Apr 29, 2007 | 02:21 PM
EJ1 wilcox's Avatar
Default Re: What Gauges Are You Running With? (chubz0r)
Boost, EGT, and oil pressure. I also have a wideband that I tune with but I have it out most of the time. I have a harness wired into my ECU so I can remove and install it really easily.
I really like having an EGT gauge, especially when doing 15 second wot pulls on the freeway.
Old Apr 29, 2007 | 04:13 PM
tony n.'s Avatar
Default Re: What Gauges Are You Running With? (EJ1 wilcox)
im about to get boost/fuel/oil greddy gauges
Old Apr 29, 2007 | 04:17 PM
envee's Avatar
boost, oil psi, oil temp
with tune that you don't mess with i don't see a need for a wideband.
Old Apr 30, 2007 | 04:12 AM
White Smoke's Avatar
i my honda
Global Mod
Search to find my answer.
Old Apr 30, 2007 | 05:20 AM
Boosted Chemist's Avatar
Default Re: (envee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envee &raquo;</TD></TR><TR><TD CLASS="quote">boost, oil psi, oil temp
with tune that you don't mess with i don't see a need for a wideband.</TD></TR></TABLE>
Incorrect, what if something happens and you start running lean? (fuel pump starts to **** ouf ect.)
I run
Wideband, egt, boost, oil pressure, water temp.
Old Apr 30, 2007 | 05:55 AM
94typeR's Avatar
Default Re: (Boosted Chemist)
exactly what i was thinking
i guess fuel pressure, wideband, boost/vac, oil pressure, oil temp, water temp should be good enough?
is egt necessary even with a wideband?
Old Apr 30, 2007 | 05:56 AM
i my honda
Global Mod
Stock water temp gauge works just fine, I would spend that money else where.
A oil temp gauge would be much more useful IMO.
Old Apr 30, 2007 | 05:59 AM
i my honda
Global Mod
Default Re: (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">
is egt necessary even with a wideband?</TD></TR></TABLE>
Thats already more then you need bro, gauges are most important when tuning.
Not so much when daily driving.
The most important gauges IMO are Widband/Boost/Oil Pressure. Then you can add Oil temp, EGT, Fuel Pressure, Water Temp in that order. If you don't have a wb then the EGT goes to the top of the list. It's harder to use an EGT gauge w/o tuning experience.
Old Apr 30, 2007 | 06:15 AM
tony n.'s Avatar
Default Re: (White Smoke)
what wideband do you guys use?
i have a friend that has a autometer cobolt or whatever wideband and it was off from the other wideband the tuner had...
Old Apr 30, 2007 | 06:18 AM
BigSam's Avatar
Default Re: (tony n.)
boost,oil psi, water temp
Old Apr 30, 2007 | 06:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Stock water temp gauge works just fine, I would spend that money else where.
A oil temp gauge would be much more useful IMO.</TD></TR></TABLE>
I just got one to tune my cold start and how my ect correction for cold days (i drive my car in 30 degree weather sometimes.)
Old Apr 30, 2007 | 09:40 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony n. &raquo;</TD></TR><TR><TD CLASS="quote">i have a friend that has a autometer cobolt or whatever wideband and it was off from the other wideband the tuner had...</TD></TR></TABLE>
Autometer does not have a wideband out that I know of...
Old Apr 30, 2007 | 10:16 AM
inspyral's Avatar
They do:
Old Apr 30, 2007 | 10:51 AM
twkdCD595's Avatar
boost, egt, wideband.
changing to boost, oil pressure, wideband (egt is displayed on this now also)
Old Apr 30, 2007 | 11:07 AM
Topdawgg's Avatar
I run Oil pressure, boost and Soon a wideband gauge too...
I have the Innovate wideband w/o the gauge and just used the laptop for street tuning when i needed it..
EGT, water temp and oil temp would be nice, but I never ran them.. and I think too many gauges looks like ***
Old Apr 30, 2007 | 11:27 AM
TURBOFTW's Avatar
Default Re: (Topdawgg)
DEFI - Boost, oil pressure and fuel pressure
Old Apr 30, 2007 | 01:31 PM
Argetnia's Avatar
Default Re: (TURBOFTW)
DEFI, boost, oil press, fuel press and boost
AEM, wideband
Autometer, egt
Old Apr 30, 2007 | 01:41 PM
PrecisionH23a's Avatar
The 3 gauges I always run on built set-ups are Oil Pressure, Boost, and A/F. This is not limited to these... I just think that AF and oil pressure are 2 of the most important ones.
