What else do I need to use with an inlinepro headgasket?
Old Sep 26, 2002 | 12:34 PM
Andrew 825SM's Avatar
Default What else do I need to use with an inlinepro headgasket?
I know its a must to use cam gears, but do you also need other things such as head studs?
Old Sep 26, 2002 | 12:43 PM
jinxproof99's Avatar
New User
Default Re: What else do I need to use with an inlinepro headgasket? (NHB Fighter)
just cam gears. nothing else.
Old Sep 26, 2002 | 02:29 PM
inspyral's Avatar
Default Re: What else do I need to use with an inlinepro headgasket? (jinxproof99)
Why do you need cam gears to run the IP headgasket? Just curious.
Old Sep 26, 2002 | 02:46 PM
Default Re: What else do I need to use with an inlinepro headgasket? (inspyral)
I heard that a thicker head gasket will change your timing. I'm debating whether or not I should run my car at 11 or 12 psi with this gasket?
Old Sep 26, 2002 | 02:47 PM
inspyral's Avatar
Get your tuning down, and oyu'll be fine
Old Sep 26, 2002 | 03:09 PM
Mr. Softee's Avatar
because it rocks the timing belt
[Modified by 94goldjungsr, 4:09 PM 9/26/2002]
Old Sep 26, 2002 | 04:34 PM
IntegD's Avatar
New User
Default Re: What else do I need to use with an inlinepro headgasket? (94goldjungsr)
What the hell is rocking a timing belt?? I thought a thicker headgasket would be the opposite of milling a head or decking a block...which will retard your timing. So, adding a thicker headgasket will advance your timing and you need the gears to get back to 0 so you won't be running soo much advance.
Old Sep 26, 2002 | 04:39 PM
BoostedED9's Avatar
Default Re: What else do I need to use with an inlinepro headgasket? (IntegD)
is this true with any thick hg?? im putting in a grex on my car soon...
JJT211
May 25, 2014 07:38 AM
rol1in0n20s
Nov 25, 2007 08:27 AM
.RJ
May 8, 2003 10:45 AM
TurboedGSR
Aug 24, 2002 06:10 PM
ic108
Jul 18, 2001 04:36 PM
