what ecu program should i use for ls with 9 psi
Old Feb 19, 2006 | 09:31 PM
4door93civic's Avatar
Default what ecu program should i use for ls with 9 psi
i have a 90 civic with a ls swap its still obd0 and i turboed it with a junkyard turbo and im running 9pounds of boost all i have done so far is retarded my timing and put on a fuel pressure regulator and turned it up.i know i need to chip my ecu any help will be highly appreciated thanx.if it helps any the turbo is the big turbo off a 3000gt vr4.
Old Feb 19, 2006 | 09:33 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: what ecu program should i use for ls with 9 psi (4door93civic)
only thing you can rub obd0 is turboedit... unless you want to convert to obd1
Old Feb 19, 2006 | 09:34 PM
Default Re: what ecu program should i use for ls with 9 psi (wantboost)
i dont know much about ecu programs or chips how do i get turboedit?
Old Feb 20, 2006 | 05:14 AM
JDM00SI's Avatar
if your ona budget, ive heard crome is real good.
If your not on a budget Hondata or neptune is cool
Old Feb 20, 2006 | 05:45 AM
fmfkid250's Avatar
Default Re: what ecu program should i use for ls with 9 psi (JDM00SI)
zdyne,
Old Feb 20, 2006 | 06:40 AM
b20turboic's Avatar
Default Re: what ecu program should i use for ls with 9 psi (fmfkid250)
Yeah Zdyne is what I run ... works good made 500whp and the car will go deep 10's (Now that I will have a cage hahaha). Zydne is actually real cheap now 300 or something and works real good and its easy as all hell to tune.
Old Feb 20, 2006 | 06:52 AM
Default Re: what ecu program should i use for ls with 9 psi (b20turboic)
i have a zdyne ecu but its for a b16 is there anyway i can remove vtec or does it have to be a turbo zdyne program?
Old Feb 20, 2006 | 07:10 AM
b20turboic's Avatar
Zdyne Gold can be anything you want .. its just like hondata use it on any ODB0 car. But it you have a zdyne silver which is just a chip burn than no it really isnt worth using.
Old Feb 20, 2006 | 07:13 AM
well im not sure all i know is it is a pm6 that was shipped off to zdyne and now its obdo dohc vtec so how do i find out if its zdyne gold or silver?
Old Feb 20, 2006 | 07:18 AM
delsolnewkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door93civic &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 civic with a ls swap its still obd0 and i turboed it with a junkyard turbo and im running 9pounds of boost all i have done so far is retarded my timing and put on a fuel pressure regulator and turned it up.i know i need to chip my ecu any help will be highly appreciated thanx.if it helps any the turbo is the big turbo off a 3000gt vr4.</TD></TR></TABLE>
this is a little scary, are you driving it that way?
also the parallel turbos on a vr-4 are the same size (tiny, trying to squeeze 9lbs out of one is going to be hard/imposible near your redline), so i wonder what you mean by "the big turbo", most v6s use parallel turbos of the same size, like the skyline. the logic is two smaller turbos spool faster than one big one. sequential turbo systems (one bigger one smaller) are less common, like the mk4 supra.
Old Feb 20, 2006 | 07:21 AM
Default Re: what ecu program should i use for ls with 9 psi (delsolnewkid)
yes i am driving it. the turbo i believe is a td08.
Old Feb 20, 2006 | 07:28 AM
how do i find these programs? crome? or turboedit? or any of them.
Old Feb 20, 2006 | 07:32 AM
b20turboic's Avatar
Zdyne gold has what looks like a phone jack on the front cover .. thats how it connects directly to a laptop to tune on the fly (no chip burning) Also should say Zdyne in gold lettering on the front cover plate.
Old Feb 20, 2006 | 07:33 AM
thanks for your help
Old Feb 20, 2006 | 07:36 AM
djnikko's Avatar
http://www.pgmfi.org is your friend
http://www.turboedit.org
Old Feb 21, 2006 | 08:57 AM
Default Re: what ecu program should i use for ls with 9 psi (djnikko)
thanx to everyone that helped me but unfortunaly my car and the rest of my cars and belongings burned to the ground yesterday.but your help was highly appreciated.
Old Feb 24, 2006 | 08:30 PM
fuuuuuuuck
TheSupremeKai
Engine Management and Tuning
10
Jun 22, 2013 05:17 AM
EF EG EK LOVE
Apr 23, 2008 09:22 PM
Fezzie
Aug 2, 2006 03:58 PM
si90rex
Jun 26, 2006 10:45 AM
