What is DRAG piping made of?
Old May 3, 2003 | 05:25 PM
B18EG6's Avatar
Default What is DRAG piping made of?
Like the toppic says... does anyone know what DRAG charge/intercooler piping is made of?
Old May 3, 2003 | 05:30 PM
TeStUdO's Avatar
i think its just a mild steel, im not sure though. i sandblasted mine and got it powdercoated
Old May 3, 2003 | 05:36 PM
Ben Huynh's Avatar
Default Re: What is DRAG piping made of? (B18EG6)
Chrome-plated mild steel.
Old May 3, 2003 | 05:42 PM
B18EG6's Avatar
Default Re: What is DRAG piping made of? (ben@importparts.com)
Thanks Ben... someone told me it was aluminum but when I showed them the rust on the inside they thought otherwise...
I thought you couldnt weld aluminum to steel, how come I was able to weld aluminum piping to the drag piping? Is it because of the chrome plating...?
Old May 3, 2003 | 05:43 PM
TeStUdO's Avatar
good i was right mild steel. i powdercoated mine because of the rust
Old May 3, 2003 | 05:58 PM
Ben Huynh's Avatar
Technically you can weld aluminum to steel but you wouldn't want to.
Old May 3, 2003 | 07:56 PM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">Technically you can weld aluminum to steel but you wouldn't want to.</TD></TR></TABLE>
how come?
Old May 3, 2003 | 08:27 PM
Ben Huynh's Avatar
I'm not a professional welder but I've tried this before. Steel and aluminum welding require different temps and current. It's very hard to weld and the result is not pretty if you can do it at all.
Old May 3, 2003 | 11:22 PM
B18EG6's Avatar
Haha tell me about not being pretty. I took the drag piping to a buddy today and he successfully welded aluminnum piping to the drag mild steel... we used aluminum spool, and mig welded it... but i forgot the temps.....all i remember is that we had to set the drag on the spool real low because the soft aluminum wire kept getting hemmed up along the feed wheels...
thanks
You_Get_Vapors
May 7, 2003 01:47 PM
integra-modder
Jan 22, 2003 07:07 PM
PM-Performance
Jan 17, 2003 03:24 PM
SiRkid
Sep 16, 2002 10:54 AM
Pritos
Jan 11, 2002 08:45 AM
