What does this Cel Mean? #67
Old Jul 29, 2003 | 05:38 AM
DBallz's Avatar
Default What does this Cel Mean? #67
67 Catalyst System Efficiency System below threshold, bad catalytic converter
This is the code I pulled off. But I don't have a cat so does that mean that my 2nd o2 is bad? Or maybe my IAC? Cause when I start my car in the morning it doesn't bring the idle up it just holds at 800rpm and then when the car is warm it idles at 1000-1100rpm. Any help you guys can provide is helpfull I would like to get all these problems straightend out before I attemp to tune the car.
Old Jul 29, 2003 | 05:41 AM
ELSpool's Avatar
I think it means your primary o2 is reading the same values as teh secondary, because you have no cat. And the ECU sees the values being the same, so it throws a code. Is your gas milage really bad? YOu have to run a cat in OBDII for this reason.
Old Jul 29, 2003 | 06:10 AM
DBallz's Avatar
Default Re: (ELSpool)
See I rode around with no cat for a year but this happened. But I changed the primary already I will change the secondary next. What about the idle problems what do you think? Oh and btw my gas milage is good but my car runs rich at idle all day
Old Jul 29, 2003 | 06:18 AM
ELSpool's Avatar
Default Re: (DBallz)
Rich problem...could be the o2 heater. Happened to me, the o2 would read, but only after driving around for awhile. What happened was thw o2 heater had failed and so the engine always thought the car was "cold" because the o2 never warmed up, so it dumped more fuel to compensate and try to warm it's self up with more fuel and a higher idle. So replace it and see, but I would get ahold of a scanner first and see what the valves are between the two o2's. Like you said, weird that it's just starting now after a year. Mine was fine for about a 3 weeks, then the code started coming up.
Old Jul 29, 2003 | 10:04 AM
DBallz's Avatar
Thanks for your help now I need to get a hold of a scanner
TNight
10
Jan 10, 2014 09:42 AM
93civiconair
10
Feb 5, 2012 07:32 PM
ftrms
Oct 28, 2008 02:15 PM
impr323
Sep 8, 2005 02:57 PM
joshcivic00
Aug 16, 2005 12:57 PM
