what to do with these? HELP HELP HELP!
Old Jul 5, 2005 | 11:41 PM
Rubixcu7's Avatar
Default what to do with these? HELP HELP HELP!
like the question says... when i install my kit this weekend... what do i do with these two things?
thanks in advanced!
Old Jul 5, 2005 | 11:50 PM
inspyral's Avatar
Default Re: what to do with these? HELP HELP HELP! (Rubixcu7)
The PCV line you can just vent to the atmosphere, run to a catch can, or run to a nipple on the inlet pipe before the turbo. The other thing is the IAT sensor, and some people leave that dangling, but you can mount it back into the upper charge pipe in front of the throttle body(like it is now), but you have to make sure there's a good seal around it so you don't leak any boost.
Old Jul 5, 2005 | 11:54 PM
Rubixcu7's Avatar
will i run a cel if i let the IAT sensor just dangle?
Old Jul 5, 2005 | 11:56 PM
inspyral's Avatar
Default Re: (Rubixcu7)
I never threw a CEL when mine dangled for about a year.
Old Jul 6, 2005 | 02:29 AM
cua0's Avatar
mine's been dangling for quite a while. i ziptied it up under the throttle body so you don't see it though.
Old Jul 6, 2005 | 05:03 AM
-Trinitron-'s Avatar
It shouldn't be a problem letting it hang. I would suggest extending the wire and putting it in the inlet pipe before the turbo. That is how the Greddy kit is designed.
Old Jul 6, 2005 | 05:30 AM
Tactic$'s Avatar
Default Re: (-Trinitron-)
not to stomp on this thread, but i have a semi-related question.
What to do with the second O2 sensor when i go to obd I ?
Old Jul 6, 2005 | 10:29 AM
Quad-Damag's Avatar
Default Re: (Tactic$)
^^ just let it hang, and zip tie it out of the way, ur best bet, or u can disconnect it, and leave it pluging the hole
Old Jul 6, 2005 | 10:40 AM
GWInquisitor14's Avatar
Default Re: (Quad-Damage)
yeah u can just let it dangle, it will just read the temp of the air in the engine bay
FW_EJ8
Feb 18, 2008 10:09 PM
turbosi03
Nov 11, 2004 01:28 PM
