what compression ratio?
Old Sep 10, 2006 | 06:36 AM
cycleguy88's Avatar
Default what compression ratio?
Hey guys I am new to this forum and just wanted to see if anyone knows what ratio I should run on my lsvtec with a JRSC kit with 12lbs of boost. I currently have ls eagle rods and 9.5:1 ls pistons in a ls block. What is the compression ratio this gives me with a GSR head? What compression ratio pistons should I get if not these? What would give me ITR compression but in my lsvtec? Thanks. I was going to go turbo but changed my mind. I have serched and havnt seen anything that would help me.
Old Sep 10, 2006 | 06:39 AM
DaveF's Avatar
Default Re: what compression ratio? (cycleguy88)
definitly sell the jrsc ASAP
Old Sep 10, 2006 | 10:30 AM
cycleguy88's Avatar
Default Re: what compression ratio? (dturbocivic)
sorry, but I like the JRSC
Old Sep 10, 2006 | 11:27 AM
stockb18c's Avatar
10.17 to 1 thats what you ratio would be im for sure
stockb18c's Avatar
http://www.zealautowerks.com/
Old Sep 11, 2006 | 02:12 AM
cycleguy88's Avatar
Default Re: (stockb18c)
thanks, so now my question is if I use the pistons I have then will I get good numbers from the JRSC? the dyno numbers on their website is with stock compression ratio b18c5 & c1 so I wonder if I shouldnt bump up the compression to what a stock ITR is.
crxgsr91
Oct 28, 2004 07:49 AM
untitled
Jan 6, 2004 07:48 PM
1strdko
Aug 18, 2003 09:32 AM
flatline
Apr 13, 2003 08:49 PM
Stunna BEN
Mar 30, 2003 05:45 PM
