what can i do with my IAT sensor?
Old Apr 1, 2009 | 09:07 PM
pjr710's Avatar
Default what can i do with my IAT sensor?
here is a picture of my engine bay, my iat sensor is in the silicone coupler right before my intake manifold, if you look you can see it. anyway i have to be leaking boost from that hole because its not air tight, so what options do i have?
Old Apr 1, 2009 | 11:02 PM
locash's Avatar
Default Re: what can i do with my IAT sensor?
I have the solution on my site, but last time I said it, the post got deleted, so I won't mention it, lol.. Basically, have a fitting welded onto the charge pipe that holds the IAT..
Old Apr 2, 2009 | 08:09 AM
pjr710's Avatar
yea ive heard that before actually. my IAT isnt screw in tho, would i have to buy one of another car?
Old Apr 2, 2009 | 09:25 AM
dephtone's Avatar
Just use some silicone to put around the sensor to make it air tight. My buddy just drilled a hole in his tubing and put some clear silicone around it so it doesn't leak.
Old Apr 2, 2009 | 09:36 AM
pjr710's Avatar
yea .. i tried that but it was like a 5 minute thing and i ended up not getting the silicone around the whole thing and it ended up cracking anyway, thats what i'm gunna do when i get some time
Old Apr 2, 2009 | 10:55 AM
same ol Steve's Avatar
maybe before the turbo in the intake tube probably not much warmer there than where its at now
Old Apr 2, 2009 | 11:01 AM
b20beast83's Avatar
get one from a crv
Old Apr 2, 2009 | 12:38 PM
dephtone's Avatar
Use good silocone, not the quick drying JB weld. Something that must cure for 24 hours.
Old Apr 3, 2009 | 08:25 AM
TurboChurch's Avatar
I've said it before and now again, even in the thread Locash got deleted from. B20 screw in sensor, there are other hondas that have scerw in sensors. Just get one and weld a nut to your charge pipe. Screw it in with teflon tape, extend wires if necessary and call it done. Its not rocket science. If you use the sensor that B16/GSR have that bolt into the intake manifold you can make something up or I think Locash said he knows of something that will work with that style. Either way, sell the plug in style to another 99-00 civic owner and get a screw/bolt in style and be done. It works with the ECU so dont worry about asking that question next.
ROOSTER.
Jan 31, 2014 05:42 PM
gsr336
Jun 18, 2007 11:56 AM
jeffk182
Feb 17, 2006 05:31 PM
VTECorona
Aug 17, 2002 11:51 AM
JohnShaft
Sep 27, 2001 12:51 PM
