what bit for block notching?
Old Mar 18, 2008 | 02:20 PM
turbo sol's Avatar
Default what bit for block notching?
ok, so i have done this before with some grinding pieces, but I have to think there is a better bit out there for this. I have a air powered die grinder. (like the photo with those bits)
http://www.harborfreight.com/c...44716
Old Mar 18, 2008 | 02:40 PM
philafelman's Avatar
Default Re: what bit for block notching? (turbo sol)
depending on how much you want to remove, i would think a cut-off wheel would be good with a sanding pad or cookie or a wire wheel on the die grinder for smoothing out.
Old Mar 18, 2008 | 02:55 PM
stealthmode62's Avatar
Default Re: what bit for block notching? (philafelman)
I used bits like these:
but this might be more fun:
Old Mar 18, 2008 | 04:05 PM
mrbsponge's Avatar
Default Re: what bit for block notching? (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">I used bits like these:
haha steve, help the *** out, WHERE DO YOU EGT THOS nifty tools,
Old Mar 18, 2008 | 04:08 PM
platinum00's Avatar
Either tool will work. You just need to mark the block first and stay within the lines. It's like cutting paper
-platinum
Old Mar 18, 2008 | 05:09 PM
Tippyman's Avatar
Default Re: what bit for block notching? (platinum00)
Die grinder and a carbide bit.
MAC tools, lifetime warranty on both.
Old Mar 19, 2008 | 05:57 AM
turbo sol's Avatar
Default Re: what bit for block notching? (Tippyman)
ouch!
http://www.mytoolstore.com/astro/astdig01.html
82.75 for those bits, that gold plating must be real!
Old Mar 19, 2008 | 06:13 AM
JShull's Avatar
I'm feeling the grinder action.
Carbide bits will get it done faster but I'm sure the bits you have will get the job done it will just take ya longer.
Old Mar 19, 2008 | 11:26 AM
dpetro1's Avatar
Default Re: (JShull)
Sawzall worked for me.
Old Mar 19, 2008 | 02:29 PM
mike93eh2's Avatar
carbide bits like those only cost me a few bucks at my local westlakes...
Old Mar 19, 2008 | 02:34 PM
Legion's Avatar
* B A N N E D *
Those bits are designed for steel, not aluminum. They clog up almost instantly if you use them on aluminum. Then you have to sit there with a nail and try to pick off all the little pieces of stuck aluminum from the carbide teeth... It sucks.
Old Mar 19, 2008 | 02:37 PM
mike93eh2's Avatar
Default Re: what bit for block notching? (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">
Those bits are designed for steel, not aluminum. They clog up almost instantly if you use them on aluminum.</TD></TR></TABLE>
aluminum sleeves ???
and btw they work great on aluminum for me.
Old Mar 19, 2008 | 02:44 PM
Legion's Avatar
* B A N N E D *
Default Re: what bit for block notching? (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">aluminum sleeves ???</TD></TR></TABLE>
Hmm... good point. I guess clogging a steel bit with aluminum is better than breaking an aluminum bit on the iron liner. All I know is that I asked about using a steel bit (exactly like the ones posted above) on aluminum in the fab forum and everyone said not to because it would clog the bit. I ignored them and did it anyway and the bit clogged nearly entirely and became worthless. The aluminum pieces really stick in there.
Old Mar 19, 2008 | 02:55 PM
mike93eh2's Avatar
Hmm... good point. I guess clogging a steel bit with aluminum is better than breaking an aluminum bit on the iron liner. All I know is that I asked about using a steel bit (exactly like the ones posted above) on aluminum in the fab forum and everyone said not to because it would clog the bit. I ignored them and did it anyway and the bit clogged nearly entirely and became worthless. The aluminum pieces really stick in there.</TD></TR></TABLE>
too much rpm
Old Mar 19, 2008 | 09:36 PM
viet_boi_racin's Avatar
Old Mar 19, 2008 | 09:38 PM
I had to do this on a buddy's block, I used the same bit pictured above. and worked at it slowly.
Modified by viet_boi_racin at 10:43 PM 3/19/2008
shaunk18
Nov 27, 2007 05:15 PM
Sterndotstern
25
Jan 13, 2006 08:04 AM
philibuster
Oct 21, 2005 05:53 AM
94accordsedan
35
Jun 21, 2005 06:51 AM
Brewer
Aug 29, 2004 08:19 PM
