What for better traction?
Old Jan 16, 2002 | 02:06 PM
Trajic's Avatar
New User
Default What for better traction?
WHat can I do to get better traction in my integra.
Old Jan 16, 2002 | 02:34 PM
JM Performance's Avatar
Default Re: What for better traction? (Trajic)
ditch the turbo
dont pay any attention to me
Old Jan 16, 2002 | 03:35 PM
falcongsr's Avatar
What is this crap?
convert it to rear wheel drive.
Old Jan 16, 2002 | 03:40 PM
meanteg's Avatar
New User
Default Re: What for better traction? (falconGSR)
get the AWD system from the JDM integra AWD.
Old Jan 16, 2002 | 03:51 PM
DIRep972's Avatar
Smarter than you
slicks, suspension, clutch
Old Jan 16, 2002 | 03:52 PM
Default Re: What for better traction? (meanteg)
whaaaaaaa??????!!!!!
JDM Integra AWD??
Old Jan 16, 2002 | 04:05 PM
TurboSedan's Avatar
New User
Default Re: What for better traction? (00SilverLS)
Quaife LSD
Old Jan 16, 2002 | 04:14 PM
Phantom's Avatar
your best bet to signifigantly improve tractionis stickier tires, but they just aren't good for street driving
Old Jan 16, 2002 | 04:26 PM
88CRXHybrid's Avatar
Default Re: What for better traction? (Phantom)
Z10 front crossmember
Old Jan 16, 2002 | 05:37 PM
lazyvietboi's Avatar
Default Re: What for better traction? (88CRXHybrid)
i agree
Old Jan 16, 2002 | 06:24 PM
Aahj's Avatar
Default Re: What for better traction? (97CivicFerio)
Quaife LSD
I agree with this, too
Old Jan 16, 2002 | 06:25 PM
Default Re: What for better traction? (ajn)
Quaife LSD
how about a combo? woohoo
Old Jan 16, 2002 | 06:28 PM
Aahj's Avatar
Default Re: What for better traction? (lazyvietboi)
Old Jan 16, 2002 | 06:44 PM
Skrilla's Avatar
If you're talking straight line traction then I'd say some stiff shocks in the rear to help prevent weight transfer and Quaife LSD as stated before. I would also say a front strut bar. If you want some speed for the corners then I say get all the strut bars, a sway bars pair (from the same company if possible) and adjustable coilovers like a combo. If not then some ground control adjustable slip-overs and some tokico illumnia 5-way adj.
Old Jan 16, 2002 | 07:04 PM
93LSivic's Avatar
Wheelie bar!
Oh nevermind. Z10 radius arms, sticky tires with low treadwear rating, high spring rate in the rear, LSD, clutch, and dry pavement.
That should do it>>>>>
Old Jan 16, 2002 | 07:10 PM
DIRep972's Avatar
Smarter than you
Default Re: What for better traction? (Skrilla)
before you go buying an 800$ LSD, or 350 on Z10 radius arms get good tires first.. Then get a good clutch, then get a good suspension(coilovers w/ adj shocks or full coilovers), After that think about getting Z10 arms and LSD.. and if u r racing on the track, just get some fuggin slicks and get it all over with..
oh yeh make sure if u r racing run low tire pressure.. and practice, learn what bogs, learns what burns out.. learn what launches, learn your car
[Modified by DIRep972, 4:15 AM 1/17/2002]
Old Jan 16, 2002 | 10:30 PM
sa21199's Avatar
ive never heard of this...could you give me a link for more info on this
Old Jan 16, 2002 | 10:40 PM
Pritos's Avatar
New User
Default link
http://z10eng.com/
Old Jan 17, 2002 | 01:47 AM
Lei Siew Long's Avatar
Default Re: link (Pritos)
everything mentioned above and if you're boosting, use a boost controller with a scramble feature.
Old Jan 17, 2002 | 05:04 AM
jamal-188's Avatar
Default Re: link (boostedeg6)
Solid or at least poly motor mounts to help reduce engine flew.
Old Jan 17, 2002 | 07:21 AM
Flamenco-T's Avatar
Default Re: link (jamal-188)
yeah, but you'll hate it on daily driving though
Old Jan 17, 2002 | 08:06 AM
rtype11's Avatar
lose the anti sway bar upfront and go poly bushings and lock up the rear suspension with airbags/2x4"s etc....lower tire pressurefeather the clutch/get better weight transfer up front, burn out in VHT or coke or javex or water.
Old Jan 17, 2002 | 08:18 AM
Pritos's Avatar
New User
I use the avc-r scramble boost to drop -.20bar in first from .80. It helps out a lot!
Old Jan 17, 2002 | 08:19 AM
Flamenco-T's Avatar
yeah, unfortunately mine is the first gen AVC-R, don;t have that feature...
Old Jan 17, 2002 | 02:21 PM
Default Re: link (Flamenco-T)
are you sure? because even the generation before that the AVC-D had a scramble feature. but, i believe it was an option for the product.
