What bearings to use?
Old Jun 26, 2009 | 06:59 AM
matt94z's Avatar
Default What bearings to use?
Building a B16 turbo for my 00 EM1. This is my daily driver, so I want it to be relaiable and last. My power goal is 275-300 wheel hp. As for the bottom end, its fully balanced and has all ARP studs, Eagle H-beams, and Wiseco pistons, ... the stock crank is un-cut.
What bearings do you guys reccommend?
Old Jun 26, 2009 | 07:07 AM
th3pwn3r's Avatar
Default Re: What bearings to use?
Ones that you've measured to fit properly. OEM, ACL? It also depends on what kind of tolerances you want to run depending on how you want it to respond.
Old Jun 26, 2009 | 07:15 AM
matt94z's Avatar
wow good story, please tell another!
Found ACL rod/main on eGay for $69 shipped... any feedback on ACL's?
Old Jun 26, 2009 | 08:33 AM
93supercoupe's Avatar
if u search around ul find some text on the ACL's not responding well to daily use.I would go OEM, they tend to work out good.
Old Jun 26, 2009 | 08:35 AM
EARLdaSQUIRREL's Avatar
official honda whore
i would use oem, if you have a built bottom end why not spend the little bit extra
fyi i have used acl with good and bad luck, on one motor they were perfect and had excellent clearances, on another they were a bit small and led to not enough oil pressure at idle
Old Jun 26, 2009 | 09:01 AM
mar778c's Avatar
Community Builder
Community Influencer
The correct answer.
Sounds like another episode of "this is a new motor, why is it broken?" Lol
Old Jun 26, 2009 | 03:02 PM
matt94z's Avatar
Originally Posted by mar778c
The correct answer.
hahah cool.
Thanks guys, I'll go with OEM
ExVtec
Nov 23, 2014 02:49 PM
bigbpatel
11
Jan 8, 2013 02:53 PM
Mhollaek9
Sep 1, 2007 03:06 PM
Cruz2000
Mar 22, 2007 09:17 AM
crxking1
Jan 14, 2007 06:57 PM
