Went to the Dyno...Impressed
Old Jun 16, 2005 | 12:55 PM
  #51
Threads's Avatar
Lost is black, I already ordered the rims I alway wanted a set....
therealprojeckteg, to my knowledge there were no "correction" numbers set. Even if they were i don't think it would be off by 60hp. Also why would they have correction numbers for me and not for everybody?
adseguy, I ain't gonna blow my motor. I don't give my .bin to everybody who wants it....sorry.
Old Jun 16, 2005 | 01:06 PM
  #52
SOHC_MShue's Avatar
Default Re: (Threads)
The best way to tell if its really making this kind of power is to take it to the track. Obviously the trap speed will tell whether or not this is a 200whp or 250whp car.
Old Jun 16, 2005 | 01:22 PM
  #53
EJ1 wilcox's Avatar
Default Re: (SOHC_MShue)
Those are incredible numbers...
It just doesn't make sense to me though. I've seen a lot of SOHC turbo setups, even with larger turbos and a few more pounds of boost not making as much power as you...
What do you think causes your car to have an extra 50 or so horsepower over all the other similar setups? What's your secret?
Those who have seen the .bin, what's the timing look like?
Old Jun 16, 2005 | 01:25 PM
  #54
Threads's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Those are incredible numbers...
Those who have seen the .bin, what's the timing look like?</TD></TR></TABLE>
My secret is that the dyno was probably off a few horsepower(20-30hp). I doubt its my .bin because I think my timing is conservative. Also, SOHC_MShue is the only one to see my .bin and I appreciate it if he doesn't spread it to everybody, but I don't mind him talking about it. I do have a very nice exhaust system and there were little things i did here and there to help.
  #55
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threads &raquo;</TD></TR><TR><TD CLASS="quote">
I was just jokin ....nice numbers on that low boost. I just wanted to know total timing at your 10 or 11 PSI ....if that's OK.
Old Jun 16, 2005 | 01:27 PM
  #56
Threads's Avatar
1.13psi retard .17 degrees per psi
3.45psi retard .34 degrees per psi
5.78psi retard .51 degrees per psi
8.09psi retard .65 degrees per psi
10.41psi retard .80 degrees per psi
11.03psi retard .90 degrees per psi
This is pretty much what i am running
Old Jun 16, 2005 | 01:34 PM
  #57
SOHC_MShue's Avatar
yea you have basically a pretty standard step retard. I think more than likely the dyno is off by a little, but its probably very possible that you were making around 210-215whp.
Old Jun 16, 2005 | 01:40 PM
  #58
Threads's Avatar
I think if my timing was tuned and my actual tune was a bit more precise, I think i could have gotten 260whp
Old Jun 16, 2005 | 03:07 PM
  #59
civiccpedx's Avatar
damn 240whp with stock internals, some good numbers but id be a bit worried about throwing a rod or something
Old Jun 16, 2005 | 05:10 PM
  #60
Threads's Avatar
Default Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">damn 240whp with stock internals, some good numbers but id be a bit worried about throwing a rod or something</TD></TR></TABLE>
250whp.....
I only run that much when i need to lay a real smack down. I run 8psi daily.
Old Jun 16, 2005 | 05:12 PM
  #61
1boostedcivic's Avatar
I dont really think ur motor is in too much trouble with that kind of power. Hondas have came along way since the fmu, afc hack days. \With standalone and a phenomenal tune a stock sohc can run on 250whp for more than a year tilll problems. the rods are toothpicks but they can take a beating.
Old Jun 16, 2005 | 05:21 PM
  #62
LoSt is BlaCk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threads &raquo;</TD></TR><TR><TD CLASS="quote">Lost is black, I already ordered the rims I alway wanted a set....
in that case, ROCK those bad boys !!! as far as all the questions about the numbers...who cares, they are solid, sohc motors are not garbage...one does not have to swap to be fast...one does not have to overbuild there motor to feel safe running it...let the man enjoy his dyno sheet!
Old Jun 16, 2005 | 05:28 PM
  #63
Threads's Avatar
I am putting 16" Royal Gunmetal Grids wrapped in 205/40 Azenies on my civic that is not lowered. I am worried that it will look like a 4x4. Hopefully, I wont have to hold them until i get a drop
Old Jun 16, 2005 | 08:18 PM
  #64
SOHC_MShue's Avatar
damn that will be a 4x4 with stock suspension man. Go for the 15" grids
Old Jun 17, 2005 | 04:54 AM
  #65
Threads's Avatar
Is 1" that big of a difference?
Old Jun 17, 2005 | 05:11 AM
  #66
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threads &raquo;</TD></TR><TR><TD CLASS="quote">Is 1" that big of a difference?</TD></TR></TABLE>
Must... not... make dirty joke...
Old Jun 17, 2005 | 07:10 AM
  #67
SOHC_MShue's Avatar
More than likely you car will look like it sits up high even on 15's with stock suspension. I used to ride around with my slipstreams on stock suspension and my car even looked like a 4x4.
Old Jun 17, 2005 | 07:34 AM
  #68
BlackCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threads &raquo;</TD></TR><TR><TD CLASS="quote">1.13psi retard .17 degrees per psi
This is pretty much what i am running</TD></TR></TABLE>
using the p28 bin or p2p bin ??
currently my y8 is running the p28 bin with total timing at 10psi set to 16*
but with the stupid y8 timing tables im scared to go any higher
Old Jun 17, 2005 | 07:45 AM
  #69
Zer0DazE's Avatar
i can just about promise that the high numbers came from a messed up temp sensor on the dyno. we use the same one, and the temp sensor is touchy... (f'd up ground wire)
we had a h22 lay down an extra 60ish whp becasue of it for a run.
fixed the sensor, and the numbers came back in line.
Old Jun 17, 2005 | 08:25 AM
  #70
92SleepyHB's Avatar
Default Re: (Zer0DazE)
stock ingnition???????
Old Jun 17, 2005 | 09:58 AM
  #71
CRX T-Si's Avatar
Default Re: (92SleepyHB)
Man this is hard to believe but you got th Dyno to prove it so I give ya mad props.
Your **** made more TQ then mine and I have a B16.......
What ever you did to your motor...continue the good work.
Old Jun 17, 2005 | 12:06 PM
  #72
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SleepyHB &raquo;</TD></TR><TR><TD CLASS="quote">stock ingnition???????</TD></TR></TABLE>
stock should be fine for that much power.
Old Jun 17, 2005 | 12:17 PM
  #73
Zer0DazE's Avatar
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Man this is hard to believe </TD></TR></TABLE>
thats because it didnt happen, and either the temp sensor on the dyno is fuct, or the correction multiplier is wrong.
Old Jun 17, 2005 | 01:07 PM
  #74
Threads's Avatar
Showing a dyno sheet = never happened ?????
I think you didn't phrase what you meant correctly.
Old Jun 17, 2005 | 01:21 PM
  #75
92SleepyHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
stock should be fine for that much power. </TD></TR></TABLE>
I understand that.....just trying to figure out why his graph is so jumpy.
