went back to turbo
I have been doing the NA thing for a bit and it just wasnt cutting it so I went back to boost.
I have had 370+hp to the wheels with a different set up so I know what big power is all about. On this set up I decided to go back to what I started with....small turbo, instant boost, great drivability...and CHEAP! I've got $1200 in the whole kit.
I am only running a JR FMU at the moment but standalone is right around the corner. FMU is not that bad at all though, I ve got a V2 J&S hooked up to pull 1degree of timing per pound of boost. Car drives absolutely fantastic, I will never do big turbo again..
LHT Performance (727-344-1800) in Pinellas Park, Fla did the whole thing. They are awesome!
here is a list of mods:
Motor and Drivetrain
B18C5 block Golden Eagle Sleeved
Stock ITR head and cams
Endyn 9.8:1 84.5mm
Crower Rods
Apexi VAFC
ARP Head bolts
Endyn Ported Intake manifold
Mugen Thermostat
Mugen Oil Cap
Mugen valve cover
DC Sports short shifter
JUN lightweight flywheel
Clutchmaster stage 3 Clutch
GSR 5th Gear (172mph top speed)
MSD High Power Anti Vibration Coil and Distributor cap
LHT Performance Engine Damper
Endyn Catch Can
Fluidyne Radiator
Gator Racing stage 2 axles
Turbo Kit
Turbonetics T3 turbo off a Chrysler LeBaron. V Trim T4 comp wheel, clipped exh. Wheel
Rev Hard log manifold
Tial 38mm wastegate
Vibrant silicone connectors
Mitsubishi Starion Intercooler
2” piping to IC, 2-2 1/2” piping from IC to engine
Bosch high boost BOV
2 ½” flared to 3” Downpipe
Closed loop wastegate dump
Exhaust System
DC Sports Race Header
Test Pipe
Mugen Twinloop Exhaust
Fuel
Prelude 91-96 injectors 345cc
B&M fuel pressure Reg.
Walboro 255lph fuel pump
Apexi VAFC
JR 6:1 FMU
Engine Management
JDM 98 spec ITR ecu
J&S v2 Safeguard
Suspension/Brakes
Acura NSX front Calipers
Acura Legend 28mm front rotors
LHT Performance Master Cylinder Brace
Mugen Sport Type R Coilover system
Mugen 26mm rear sway bar
Mugen Front and rear tower bars (authentic)
Miscellaneous
Apexi Ver. 1 Rev-Speed meter
JDM Honda badge
JDM Honda H badges
JDM red stitched shift boot
JDM ITR steering wheel
Mugen shift ****
The car:
scott
scott
Modified by scooter at 2:34 PM 7/23/2004
Endyn 9.8:1 84.5mm
Crower Rods
Apexi VAFC
ARP Head bolts
Mugen Thermostat
Mugen Oil Cap
Mugen valve cover
Endyn Catch Can
Fluidyne Radiator
Turbo Kit
Tial 38mm wastegate
Exhaust System
Test Pipe
Fuel
Apexi VAFC
JR 6:1 FMU
Engine Management
JDM 98 spec ITR ecu
J&S v2 Safeguard
Suspension/Brakes
Miscellaneous
JDM Honda badge
JDM Honda H badges
Mugen shift ****
The car:
scott
scott
yeah nothign compared to the power my small turbo gave me. not all out power but get up n go power hell yeah, my torque drops off big time up top but my HP kept on climibing, whenever i'd shift on the ls tranny i'd fall back into my sweet spot so that was alwyas good.
heh, it looks like you got a turbo for an early le baron, 84-87. your gonna have to buy or fab an adapter so you can stick an inlet hose on that thing.
good stuff though, i like it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtec81 »</TD></TR><TR><TD CLASS="quote">what i meant to say are those dyno sheets of non or vtec engines?</TD></TR></TABLE>
non Vtec.
non Vtec.
That car looks really good.
I like the setup too.
<---waiting for some numbers. midrange power on that thing must be very nice.
I've always hated stickers. But that Mugen side decal isn't actually too bad, goes with the car pretty well.
nice setup man. i like your R also. oh and where did you get that intercooler from? do you know the exact dimensions?? im looking for an intercooler from a junkyard.
I got the IC from my local junkyard about a year ago and never used it till now. I have never seen another one in may trips since.
I dont know the dimensions off hand, I will go measure it tomorrow when its light out.
scott
scott
chet
Dec 8, 2004 09:45 AM
