Welding question (Turbo Manifold)
Old Mar 14, 2003 | 07:15 AM
BoostedB20A's Avatar
Default Welding question (Turbo Manifold)
My friend and I were welding my manifold together yesterday using this welder:
This is how far we got on the manifold:
After that another friend comes over and tells us that my welder isn't strong enough to hold the manifold together under all the heat that the turbo will produce. Is this true? Or is the welder good enough to get the job done? Ijust want to make sure its ok to use before we finish the manifold.
---Don't mind the messy welds, my friend did the welding, and he is ALOT better at welding than me, so to me, those welds look good, but I know they are far from great. Thanks guys.
Old Mar 14, 2003 | 09:20 AM
Tinker219's Avatar
Default Re: Welding question (BoostedB20A)
home depot style
make sure you penetrate both sides of whatever you are welding...
Good luck...
ps...make sure that you really weld the hell out of whatever will be holding the turbo on...when that thing falls off, its really embarrasing(an experience a year ago...dont ask, only imagine) haha
Old Mar 14, 2003 | 09:34 AM
evoeone's Avatar
Default Re: Welding question (Tinker219)
if i were you i would spot wled it.and then have it tigged, actually i just bought a lincoln 135 and its awesome, but for mani's i would say to tig, try it out tho, it cant be that bad i dont think it will literally fall off but maybe just start cracking, keep an eye on it, that welder has enough power to penetrate the piping, but i dunno about the flange against the head, just grind and re weld
Old Mar 14, 2003 | 09:52 AM
Overblown-Teg's Avatar
Default Re: Welding question (evoeone)
That welder should work.. I used too use my 125 lincoln and it did a good job.. Why did you get threaded pipe though? That just looks ghetto.
Old Mar 14, 2003 | 09:53 AM
romeo619romeo's Avatar
did you just tacwelded that on to your mtor?
Old Mar 14, 2003 | 09:55 AM
home_made_turbo's Avatar
IT should hold together fine. That looks pretty bad though.
Old Mar 14, 2003 | 10:24 AM
UberTeg's Avatar
plz tell me thats not galvanized...
Old Mar 14, 2003 | 10:29 AM
Evil EG's Avatar
Default Re: Welding question (UberTeg)
I used galvanized steel for my dump tube.
Old Mar 14, 2003 | 10:46 AM
UberTeg's Avatar
Default Re: Welding question (BVM)
do you get high everytime the engine warms up?
Old Mar 14, 2003 | 10:51 AM
emr88's Avatar
The fumes when welding galvanized are TOXIC.
[Modified by emr88, 11:53 AM 3/14/2003]
Old Mar 14, 2003 | 11:34 AM
92HB_HB's Avatar
Default Re: Welding question (emr88)
aren't all FUMES toxic?? I've never heard of a healthy cigerette..
Old Mar 14, 2003 | 11:50 AM
bruthaboost's Avatar
Default Re: Welding question (92HB_HB)
Ethanol vapor isn't that bad
Old Mar 14, 2003 | 12:18 PM
civictypenos's Avatar
Default Re: Welding question (bruthaboost)
welders trick,drink milk before you weld galvonized,if you weld alot of it you will get a headache and possably sick to your stomach.
Old Mar 14, 2003 | 12:32 PM
BoostingSnail's Avatar
HAHA......HELL YEAH...GOOD ****!!....Read my Sig
Old Mar 14, 2003 | 12:35 PM
shortyz's Avatar
Default Re: Welding question (BoostingSnail)
uhm why dont u buy weld elbows?
http://www.mcmaster.com
"Unthreaded Steel Butt-Weld Pipe Fitting - Schedule 40"
Old Mar 14, 2003 | 02:16 PM
evoeone's Avatar
Default Re: Welding question (shortyz)
does look like plumbing pipe literally but mad props to homemade ghetto stuff that works, if its pretty doesnt necessarily mean you go faster, but props to you man, plus a lot of those people that have big *** tigs think that we can afford them, i like that youre using a weldpak 100 and making it work
Old Mar 14, 2003 | 03:53 PM
Hey guys, thanks for the replys. The pipe WAS threded, but I ground it all out with a di grinder then did a ghetto polish with a sand wheel. And yes it is galvanized and toxic, I know. But were still kickin. As far as welding it went, we smacked it with a hammer a few times and it broke. So we re did the entire mani. with a stick welder and used this expensive *** rod that has gold and some other **** in it. It cost 15$ for half a pound of rod. Anyways, it looks worse now, but it is 10000x stronger. Now I am having a crazy hard time trying to figure out how im going to get the turbo flange on the mani. Sidenote: That is an old engine, its blown up, I am just using it to mock up my mani while I wait for my block to get back from golden eagle.
Thanks for all the tips guys, Ill keep ya posted.
Old Mar 14, 2003 | 06:21 PM
Tinker219's Avatar
get a 2X3 chunk of square steel tubing(2 or 3 inches long), cut it, and weld it on....then drill hole for WG(if applicable).
Old Mar 14, 2003 | 06:35 PM
Smashback's Avatar
The stick welding looks worse than gasless mig?
Old Mar 14, 2003 | 07:01 PM
Default Re: Welding question (Hatchblack)
alot worse
Old Mar 14, 2003 | 07:27 PM
lazerus's Avatar
Stick welding can look damn good if you get a good stick welder
My brothers stick welds are a textbook example of how it's been done (12 years of mig/stick experience)
I would definately go with the mcmastercarr Butt weld pipe bends, and Tee's, it will look much more professional, and it really isn't all that expensive.
Here is what i use when i do manifolds for custom turbo projects.
Tig welding isn't real important, (but it's what i use.. now!) just make sure the weld joints are nice and clean, you get good penetration, and you don't have any undercut or porosity!
Brad
[Modified by lazerus, 8:31 PM 3/14/2003]
Old Mar 14, 2003 | 08:02 PM
evoeone's Avatar
thats all that matters to me at least, i will always sacrifice looks for performance, thats just me tho, gonna play with the mig tomorrow, I'll post some pcs of the welder, welds, trying to finish this turboback exhaust, and dump tube, lucky *** honda ****'s you have that T right in front, i gotta work under the damm car, keep us posted on your mani
Old Mar 14, 2003 | 08:07 PM
lazerus's Avatar
oh Definately. For me it's always performance over looks!!!
I need to take some pics of my bro's stick welding it's amazing!
The best way for you to attach it would be to torch a hole, and weld a flange on with side gussets, i think.
Brad
Old Mar 14, 2003 | 08:43 PM
evoeone's Avatar
Default Re: Welding question (lazerus)
how about welding it form the inside the grinding the welds so that wont cause ehxaust flwo problems, then also grinding on the outside, that would penetrate liek a ****, and would be strong as hell, do a few passes and you'll know taht **** aint going no where!!
Old Mar 14, 2003 | 10:57 PM
lazerus's Avatar
Yeah that works too!
