weird sounds from new turbo setup
Old May 7, 2009 | 07:37 AM
B16_4ME's Avatar
Default weird sounds from new turbo setup
when i have the clutch in everything sounds normal at idle and driving...when the clutch is out and im driving a whining sound is coming from what sounds like the transmission, my mechanic told me it would go away its just because everything is brand new. anybody ever experience something like this its a pretty distinct sound.
Old May 7, 2009 | 08:00 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: weird sounds from new turbo setup
Only time that ever happened to me was when I was very, very low on transmission fluid because it leaked so rapidly and I didn't expect it. Was it just installed?
Old May 7, 2009 | 08:12 AM
B16_4ME's Avatar
everything was just installed in the car... i just started working on the 500 mile break-in. everytime i walk out to the car or get done driving it i look on the ground for any leaks and there hasnt been anything yet.
Old May 7, 2009 | 08:51 AM
2fastek's Avatar
its the throwout bearing for sure
Old May 7, 2009 | 12:17 PM
HiProfile's Avatar
T-O bearing will make noise when you're pushing the clutch in, while the input shaft bearing will make noise when you're not. A bad bearing will make the sound a skateboard wheel does, although a dry bearing may squeal as you describe. They are $50 or so, and cheap people will sometimes avoid replacing them.
Its unlikely the gear shafts are serperating due to bad bearings, I know from experience that makes a [really cool] supercharger-like whine.
Old May 8, 2009 | 06:45 AM
B16_4ME's Avatar
thats exactly what my car sounds like...it sounds like my car has a beast of a supercharger in it and its whining only when i accelerate.
Old May 8, 2009 | 11:04 AM
FRANKBUILT's Avatar
Does the sound stay consistant throw all the gears? Is this a new tranny, What work did you have done new cluctch?
Old May 8, 2009 | 12:24 PM
HiProfile's Avatar
The tranny I had that made that noise had some really bad bearings inside it. With the amount of torque I fed that tranny, the gears would essentially start de-meshing because the shafts would not stay parallel. Helical gears that make noise are basicly bad. Next step is them grinding each other to nubs or sheering apart, along with grinding various shims to hell.
Is the tranny old or previously owned by some negligent fool who didn't run fluid??
2000-em1
Transmission & Drivetrain
Dec 29, 2011 05:52 AM
WifesVTEC
May 24, 2005 12:59 PM
ElectronBlueGsr1.8
Jul 27, 2004 05:24 AM
TypeRuz
Nov 3, 2003 05:08 PM
DeDonDeRosa
Nov 23, 2002 09:03 AM
