Weird Compression Test
Old Aug 18, 2006 | 04:17 PM
A.E Motoring's Avatar
Default Weird Compression Test
well i did a compression test the other day and it was 210 across, it use to be 215 across, but for some reason it dropped 5psi, then i did it again today and its 215 in 1 and 2 and its 210 in 3 and 4, that seem strange? its done this to me before well kinda, one day i did a comp test and it was 210 across and then tried it again the same day after a lil while or the next day and it was back to 215 across, very weird to me.
Old Aug 18, 2006 | 04:41 PM
y7turbo's Avatar
Default Re: Weird Compression Test (SPNFEDEH)
i would look at the compression tester and a minor difference in testing for your problems.
as long as your within 5-10% your all good.
Old Aug 18, 2006 | 04:53 PM
Default Re: Weird Compression Test (y7turbo)
well i dont have anyone to hold the tester so i let it rest on my strut bar
Old Aug 18, 2006 | 04:55 PM
DaveF's Avatar
maybe the diff in heat in your engine ??
Old Aug 18, 2006 | 05:07 PM
Honda Sport's Avatar
did you crank the same amount of times and did you do it with the plugs in or out? makes a difference...
Old Aug 18, 2006 | 05:13 PM
Default Re: (Honda Sport)
not really sure, its just weird to me, yea i cranked it the same amount of times, just weird how it changes sometimes or go back to wat it used to be.
Old Aug 18, 2006 | 08:04 PM
Default Re: (SPNFEDEH)
any other ideas
76 camaro car
Apr 20, 2017 04:47 AM
crazyhouse2011
Mar 18, 2013 07:50 PM
11psiTurboSI
Apr 13, 2004 11:26 PM
tgod1020
12
Oct 9, 2003 04:29 PM
