Weird clutch problem-please help troubleshoot
Old Aug 7, 2014 | 10:19 PM
unspankable's Avatar
Icon6 Clutch pedal drops to the floor when boosting/ hot - solved
Hello all,
this is my first build and I am having a few issues I was hoping I could get some help with.
First off- I have a new Howe Racing pull slave cylinder to clear my down pipe as seen here-
https://www.howeracing.com/p-7757-cl...-cylinder.aspx
Fluid I am using Pentosin Dot 4 LV here-
http://www.pentosin.net/f_brakefluid.asp
New Nissin Clutch Master cylinder
New Competition Clutch Ironman and pressure plate
When I shift at high rpm with the turbo spooled/in boost, the clutch pedal will lose all pressure and just stay on the floor when I press it. The clutch stays engaged, i.e. I can accelerate even with the clutch pedal on the floor.
I can pull it up with my foot and as I slow down/lower rpm, if I pump it with my foot pressure returns. This does not happen when I drive slowly/ in vacuum.
I see no leaks in the system when I look, and am not losing hydraulic fluid that I can see.
-Am I boiling my fluid?
-Is the pressure plate pooched?
-Any other suggestions?
Thank you very much for any input, this is frustrating to say the least.
Old Aug 8, 2014 | 08:10 AM
diatibe24's Avatar
Default Re: Weird clutch problem-please help troubleshoot
Did you bleed the system properly or did you just install the parts throw some fluid in and go?
Old Aug 8, 2014 | 10:18 AM
turbohatch96y7's Avatar
I'm pretty sure he did look at that part list buddy.
Drag section will probably be more help
Old Aug 8, 2014 | 01:07 PM
Thanks Ill post there.
Definitely bled the **** out of it both gravity and using a vacuum bleeder, no dice.
Old Aug 13, 2014 | 05:05 PM
Bad pull slave.
Switched out for Prelude slave and problem fixed.
unspankable
Aug 16, 2014 01:00 PM
rattlecannedEF
Transmission & Drivetrain
Jun 22, 2010 01:28 AM
Rickcrx
Mar 11, 2010 04:30 PM
fridayfred3p
Apr 27, 2006 03:11 PM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
