I have an AEM water meth kit in my daily B16 GT28 setup. I've had 2 throttle bodies go bad. The behavior that caused me to consider them bad is that they stick and become rough to rotate.
One was OEM. Another was Omni.
Basically the grease is being washed away from the bearing surfaces. The boost pressure must be forcing the water/meth mixture through the small crease where the throttle plate rotates. It's a pain to have to regrease my throttle bearings every month or so depending on how much I'm flooring it. I would like to find a solution.
One idea I have is to run a TB spacer and have the nozzle there, after the TB. Does anyone have any experience injecting after the TB? My main concern is even distribution of mist between the cylinders.
It means that you have your sprayer too close the throttle body opening itself. You need to back the nozzle spray up about 3 or 4 inches at the elbow of the intercooler connecting to the throttle body. The methanol is not having enough time to atomizer and you're killing your TBs as a result of it.
If you're not using direct port injection (like having each runner on the manifold tapped with a meth injector) then the next best thing is to have the meth injection as close as possible to the intercooler on the cold side piping. That way the spray has as much time as possible to atomize and evenly distribute itself in the air stream before it reaches the TB/manifold.
I have my injection point at the bend after the intercooler, a good 2 feet before my TB. See pics as stuff looks right now. Dirty and all. (yeah, flasks are my catch cans)
You’re methanol nozzle bung looks way too tall. The nozzle should be at least even with the inside of your ic piping. I bet that alone is disrupting the atomization of the methanol. Is it pooling down in your intercooler too?
