Wastegate setup help: Profec spec II
I've got an external wg and a Profec spec II. I do use both the low and high setting using a steering wheel switch button Greddy sells.
I do this for low boost in 1st/2nd, and high for 3rd and up.
I want to: run 12psi in 1st/2nd gear and switch over to 32 for 3rd and up.
But I thought if you install a 12psi spring in the wg that the maximum boost you can run is double the spring pressure of 12, meaning 24?
Do I have that wrong? Or is it just a rule of thumb?
The solenoid does about 2.5 times the wastegate spring that is used.
Interesting how you're using the Low/High setting. I have the remote switch as well, and I never thought about using it like that..
It works great!
Traction in 1st/2nd around town and full power in 3rd gear and up. I'm not a fan of the traction control devices available to me, nor their price. I don't have the patience for a rear wheel vehicle speed sensor setup for boost control, nor the money/patience for boost by gear.
So it works easy enough.
Thanks for the reply, that answered my question perfectly. So for 32psi I would need 32/2.5 = 12.8 spring. So my 15psi spring I have laying around will work just fine.
Reason for issue is I put in a 7psi helper to the 15psi and didn't run a boost controller for a while. Realized I couldn't go below 22psi after adding the Profec and utilize it as a tool.
I have a profec B, which im sure is a similar solenoid. When I tuned my car I had a 5psi spring in my tial 44mm (small red) We were able to squeeze 18psi out of it. I have since put a big red (10 psi) spring in it and I have the profec b set to about 50% on high boost and it makes 18psi. NO creep whatsoever.
Urinemachine
May 12, 2010 01:53 PM
